Hazard Light failure
Old Dec 11, 2007 | 02:44 PM
starkiller's Avatar
starkiller
Default Hazard Light failure
I haven't opened up any fuse boxes yet, but is there a fuse for the hazard lights only?
My car doesn't even have 700 on the odometer and they don't work.
Old Dec 11, 2007 | 05:31 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
If it's a brand new 07, take it back to the dealer. If you screw something up, you can forget your warranty.
Old Dec 11, 2007 | 05:33 PM
djclongisland's Avatar
djclongisland
and its close to x-mas, so they problly have free cookies in the waiting room!
Old Dec 12, 2007 | 04:33 PM
starkiller's Avatar
starkiller
Would rather replace the fuse myself then wait 2 hours for someone else to do it.
None of the electrical equipment has been messed with.
Old Dec 17, 2007 | 03:51 AM
bamyi's Avatar
bamyi
If you open up the fuse box, there is a diagram that tells you which fuse represents what. The fuse box is located on the driver's side underneath the steering wheel on the left side.
Old Jun 17, 2011 | 11:52 PM
garry444's Avatar
garry444
Hi Mate,
How did you get resolved ? my Haz lights not working on my 350z, only just got it.
Regds
Old Jun 18, 2011 | 03:15 AM
winchman's Avatar
winchman
The hazard lights are also the turn signals, so those fuses will carry the power when the hazard switch is used. The hazard switch itself is only connected to the Body Control Module and ground.
If the turn signals are working, the problem has to be in the hazard switch, the BCM, the wiring, or the ground connection.
If the turn signals don't work, check the fuses and other parts of that system. It's all covered in section LT of the service manual.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
