P0300 Random Cylinder misfire
Old Dec 18, 2007 | 01:24 PM
350 Rookie's Avatar
350 Rookie
Default P0300 Random Cylinder misfire
I have a single turbo 04z. It is tuned with a reflash.
i checked my CEL code today and got a p0300 with is a random cylinder misfire which means i wont pass emissions.
Now my question is. Is the ECU confused and reading the misfire cuz of the turbo kit or is it really misfiring. What needs to be done in order for the light to go away permanantly. Tomorow (wednesday), i will take out the plugs and check the gaps and the overall condition of the plugs. I will also check the wires to make sure nothing is damaged to cause the misfire. But thats all i can think off. ANy ideas?
Old Dec 18, 2007 | 02:35 PM
SpeedRcr's Avatar
SpeedRcr
well you can try resetting and see if the code comes back, you could have a bad coil pack
Old Dec 18, 2007 | 02:51 PM
Biochem7's Avatar
Biochem7
Regular
Go to Wal-mart and get a code-reader that can erase codes. I don't believe its the coil pack unless there is a specific cylinder misfire. Just something you have to live with going FI.
Old Dec 18, 2007 | 03:29 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Have you bounced it off the rev-limiter much?
Old Dec 18, 2007 | 04:53 PM
VIZAGE's Avatar
VIZAGE
I tell you, I bounced off the limiter few several back and I thought the motor blew. Heart sunk and life stopped. Then I realized it was built motor time. But the it was just a scare. Maybe next time. Car still runs good.
Old Dec 18, 2007 | 04:56 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
yeah the po300 code will pop up if you bounce it off the rev limiter more than like 2 times it sucks something awful.
Old Dec 18, 2007 | 04:58 PM
350 Rookie's Avatar
350 Rookie
ya i have a scan tool and i can erase it. thats what im gonna do when i go for emmissions. Do you guys think ill still fail with the code gone?
and no, i havent bounced off the rev limiter and i dont even beat on this car at all. once in a while, ill hit 5 grand but thats it.
Old Dec 18, 2007 | 05:36 PM
350 Rookie's Avatar
350 Rookie
is that true of na and turbo or just turbo?
i dont understand why it would come up if you redline it.
Old Dec 20, 2007 | 10:20 AM
Q45tech's Avatar
Q45tech
How will you pass the visual inspection most states conduct to check for cats and underhood mods?
When you reset OBD2 it automatically shows "not ready for test" until you have cranked, driven, and warmed up a certain number of times to catch people who modify.
Old Dec 20, 2007 | 10:22 AM
350 Rookie's Avatar
350 Rookie
ok guys. i was told about the drive cycles of the z and how it should be done right after the deletion of the check engine light in order to pass emissions. anyone know about this
i deleted my code yesterday and i have drove 40 miles with the code comeing back. is it gonna coem back or is it off for good. also will i pass emissions with the code off now.
Old Dec 20, 2007 | 10:47 AM
athenG's Avatar
athenG
I do get misfire maybe once a month and always on Cyl 2. I'm going to check my plugs and see if there is any problem. Also I only get misfire on COLD Start and never while I'm driving. I have ST and passed the NY State Inspection. But like Q45tech said, every system must be ready before you pass the inspection. One quick way to find out is when you turn your ignition on, what a few seconds and if you see your CEL blink then it means it hasn't finish all the test.
Old Dec 20, 2007 | 11:40 AM
eez's Avatar
eez
LOL 5k yeah right
Old Dec 20, 2007 | 04:58 PM
350 Rookie's Avatar
350 Rookie
Originally Posted by eez
LOL 5k yeah right
why you say that. i really dont go past 5k especially with out a good tune and built internals.
Old Dec 20, 2007 | 04:59 PM
350 Rookie's Avatar
350 Rookie
well its been 50 miles since i cleared the light. im sure w/e test it had to do, its already done right.
Old Dec 20, 2007 | 06:14 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
If your tune is really rich, it will throw this code...so SGP said when they inhibited that code...
Old Jan 1, 2008 | 06:47 PM
fklentz's Avatar
fklentz
I get that code maybe every 2 to 3 thousand miles, it's strange but it always happens about 10 to 15 seconds after starting the engine after filling the tank.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
allmycarsdie
May 13, 2016 04:38 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
