HELP! OEM brake shims on non-brembo
Old Dec 28, 2007 | 04:42 AM
dunglan7's Avatar
dunglan7
Default HELP! OEM brake shims on non-brembo
I need help on the oem brake shims. My car is making this screeching noise. I found out that it's the shims that are attached to the calipers not the pads. There is a metal part that is pointing outwards causing it to rub up against the wheels. Does anyone know if I installed them wrong? I can't bend it back and I need it to hold on the pads to the calipers. Anyone happen to have pictures of how the non-brembo calipers look?
Old Dec 28, 2007 | 06:47 AM
Tim@WestCovinaNissan's Avatar
I don't have pictures for you but yes you installed them wrong if the shim is making contact with the wheel.
Old Dec 28, 2007 | 12:27 PM
dunglan7's Avatar
dunglan7
^Thanks I found out after looking at a picture.
350z82
Oct 1, 2015 06:25 PM
