My Z shut down for no reason
Old Dec 28, 2007 | 04:50 PM
Diesel350's Avatar
Diesel350
Default My Z shut down for no reason
The weirdest thing happened to my 2006 Z when I went to go put in the key and turned it NOTHING happened. I was kinda confused as to what was going on. Anything I kept trying and trying and the car would just not do anything.
So I go popped the hood to inspect the engine for a few minutes and everything looks normal so I put the key in and this time it started up normal and I noticed that the radio had reset itself because the time was different and none of my radio stations were preset.
So I am just confused as to what could have happened.
Old Dec 28, 2007 | 04:55 PM
Russ@Z1's Avatar
Russ@Z1
sounds like bad power connection
either a loose connection on power or ground
check all connections and also check battery connections for loose cables or corrosion.
ZU L8R's Avatar
ZU L8R
Viper Sellout
battery connection or ground?
Old Dec 28, 2007 | 04:57 PM
SA Z-boi's Avatar
SA Z-boi
check the the battary connection. If it reset you radio chances are that is the problem.
Old Dec 28, 2007 | 04:59 PM
Jay'Z's Avatar
Jay'Z
ChEcK the connection..
Old Dec 28, 2007 | 05:52 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Could also be a dying battery. Maybe a dry cell. I've had the same thing happen on a couple of cars.
Pleask
Dec 21, 2021 03:17 PM
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
carid
Misc.
Sep 10, 2015 06:16 AM
