what's wrong with my car?
Old Jan 24, 2008 | 06:44 PM
phatz33's Avatar
phatz33
Default what's wrong with my car?
So this morning, I started my car to see that the brake and battery light lit up on the dash, moreover, the steering wheel won't even turn unless I use all my force. I did have my steering wheel replaced recently from nissan under warranty. I just drove it yesterday and it was perfectly fine, and I replaced my battery about 3 months ago. Does anyone know what is wrong? Could it be that when Nissan replaced the steering wheel, they didn't tighten something and now it's loose?
Old Jan 24, 2008 | 06:48 PM
VQZ33_Jake's Avatar
VQZ33_Jake
move your steering wheel back and forth while insterting your key and turning it on...sometimes the steering wheel locks up. i dont know if this is what happened, but its worth a try.
Jake
Old Jan 24, 2008 | 06:54 PM
phatz33's Avatar
phatz33
no the car has already been started
Old Jan 24, 2008 | 06:57 PM
Kuruma-san's Avatar
Kuruma-san
really hard to steer? sounds like the Power steering is not working, maybe a belt came off? if the power steering isnt working you would have to overcome the pressure in the pump to turn the wheel which is why it would be very hard to turn.
Old Jan 24, 2008 | 06:58 PM
phatz33's Avatar
phatz33
Yah that's what I was thinking. Do you think Nissan just did not install my steering wheel correctly when they replaced it?
Old Jan 24, 2008 | 07:00 PM
Kuruma-san's Avatar
Kuruma-san
I see no reason why a steering wheel replacement would affect the PS pump, they must have been tinkering around with something.
Old Jan 24, 2008 | 07:02 PM
VQZ33_Jake's Avatar
VQZ33_Jake
hmmm..
Possible causes:
Low tire pressure: Check and adjust tire pressures.
The wheels are out of alignment: Have the wheels aligned.
The power steering box or rack or power steering pump is bad: Repair or replace steering gear or pump as required.
The fluid level in the power steering reservoir is low: Fill fluid to proper level.
The power steering drive belt is damaged or broken: Replace power steering drive belt.
The steering gear needs to be lubricated or repaired: Lubricate or replace steering gear parts as required.
Old Jan 24, 2008 | 07:05 PM
phatz33's Avatar
phatz33
Yah it's probably one of the above, but I don't get why my brake and battery light are lit up on the dash?
Old Jan 24, 2008 | 07:11 PM
shadykilla717's Avatar
shadykilla717
Originally Posted by phatz33
Yah it's probably one of the above, but I don't get why my break and battery light are lit up on the dash?
Probly some kind of safety thing to tell you to not drive??
Old Jan 24, 2008 | 09:15 PM
Kuruma-san's Avatar
Kuruma-san
If your battery light is on there could be a problem with the charging system, which would point to my belt theory, the alternator and the PS pump are on the same belt, that would explain both situations, it wouldnt hurt to take a quick look under the hood with a flashlight, would take a few secounds and would tell you right there if that is the problem
Old Jan 24, 2008 | 09:20 PM
SniperHunter's Avatar
SniperHunter
Battery + Brake = alternator. But with the steering, it sounds like a torn belt.
Edit: I see you're using an underdrive pulley. That could also be the culprit.
Old Jan 24, 2008 | 09:32 PM
Kuruma-san's Avatar
Kuruma-san
Aha underdrive
Old Jan 25, 2008 | 10:46 AM
phatz33's Avatar
phatz33
I actually sold my pulleys because they were prob the most worthless mod ever
Old Jan 25, 2008 | 11:47 AM
RedBullRR's Avatar
RedBullRR
Power Steering Belt. Mines snapped, and this car is FN difficult to turn with out it.
Old Jan 25, 2008 | 12:14 PM
phatz33's Avatar
phatz33
yah I got it towed to Nissan today and that's what it was. Thanks everyone for their inputs. Does anyone know if the belt is covered under the warranty?
Old Jan 25, 2008 | 04:34 PM
Kuruma-san's Avatar
Kuruma-san
under bumper to bumper i believe
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
Darkspy
Sep 7, 2015 09:09 PM
