Whining noise when cold
Old Jan 31, 2008 | 12:07 PM
deprived...Not's Avatar
deprived...Not
Default Whining noise when cold
When I start out on a cold day there is a whining noise coming from just forward (I think) of the panel. It goes away in about a half mile. Any ideas? Have you heard this noise?
Old Jan 31, 2008 | 12:15 PM
Tenac1ousZ's Avatar
Tenac1ousZ
was your gf in the car during the aforementioned event? j/k
Old Jan 31, 2008 | 12:21 PM
deprived...Not
No, that's different and comes from the right, but it also happens when cold. This is different. BTW it's an '06 Base model.
Old Jan 31, 2008 | 01:16 PM
Kevins350z's Avatar
Kevins350z
mine has same noise you described above. i think it's coming from either my transmission or vsld..have u changed your fluid before? mine started to make that noise right after i changed my fluid.
Old Jan 31, 2008 | 01:41 PM
deprived...Not
No fluid change that I know of. I'd take it to the dealer but he would have to drive it when it's cold. Plus, they are very frightened of anything they may have to do other than an oil change - that I pay for.
Old Jan 31, 2008 | 02:15 PM
Zboostin's Avatar
Zboostin
I have the same issue, it goes away in about 2mins on a cold start. I dont think its anything major. Just check all your fluids are where there suppose to be.
Old Jan 31, 2008 | 02:19 PM
RuNvS 350z's Avatar
RuNvS 350z
Default .
THANK YOU!!! I thought I was the only one--
'03 Touring 6-speed w/ 37k
I'm starting to think it's the Power Steering pump.. it sounds gear related at first.. but I notice it gets louder with the revs (like it might be a belt driven accessory), and it is much louder when turning the wheel and driving. Almost as though the PS pump doesn't have enough fluid when cold?!! lol
-Tim
Old Feb 1, 2008 | 05:11 AM
deprived...Not
It has to be pretty cold, below 20 degrees. The shops around here are not very service oriented. So, if it's not obvious, they're not going to get involved. If the noise could be heard when the car is warm, they might have an opinion.
Old Feb 1, 2008 | 08:49 AM
bjr's Avatar
bjr
There are at least two other threads on this. NOBODY KNOWS WHAT IT IS!
Or should I say at least, if it has been identified, nobody knows if it will cause a failure or if it is just a noisy part that will do no harm. Transmissions have been replaced only to have the new one do the same exact thing.
https://my350z.com/forum/maintenance-and-repair/310639-whistling-noise-while-cold.html
https://my350z.com/forum/maintenance-and-repair/238727-transmission-noise-when-z-is-cold.html
Happy reading. If it makes you feel any better, you are not alone.
Old Feb 1, 2008 | 08:53 AM
bjr's Avatar
bjr
Why? Nissan pays for warranty, not the dealer. It's the one thing they do that if they check that it will be covered they know how much it costs and know they will be paid.
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
