Wiring Diagram Help? B2S2 O2 sensor wiring
Old Feb 15, 2008 | 05:15 PM
03Z33's Avatar
03Z33
Default Wiring Diagram Help? B2S2 O2 sensor wiring
The blue plastic connector for the rear drivers side (USA) oxygen sensor was torn off my car by a speed bump. This is also known as Bank 2 Sensor 2. I'm trying to match up the wires but I can't seem to interpret the wiring diagram... any help would be very much appreciated!
Thanks in advance!
02 sensor has 4-wires
Black
Grey
White
White
Harness from engine/ECU has 4-wires
Black/Yellow
Pink/brown
Orange/blue
Red/Black
I just need to know which wires go to which color. This is for a 2003 350Z Coupe w/manual transmission
Old Feb 16, 2008 | 07:26 PM
03Z33's Avatar
03Z33
Got it! Thanks to "Eazzzzzzy" for the PMs and time he took to go under his car and check the wiring for me. I hooked it up as per his directions, cleared the code and 75 miles later still no codes
Thank you for all the help!
Old Jan 19, 2012 | 04:14 PM
williamwells59's Avatar
williamwells59
I have the same problem. Could someone please post how these mate up? Thanks
Old Jul 4, 2012 | 04:10 PM
brandonphil's Avatar
brandonphil
I would also like to know which wires match up. Could someone please post. Thanks
Old Feb 15, 2013 | 11:02 AM
adrunkpriest's Avatar
adrunkpriest
someone please post im having this issue as well
Old Feb 19, 2013 | 10:58 AM
03Z33's Avatar
03Z33
I no longer have my Z and didn't save the PM's. Your best bet is to find another similar year 350Z owner and have them check for you.
Old Mar 5, 2019 | 09:07 PM
Luke Spears's Avatar
Luke Spears
Anyone ever get the o2 wiring colors? Need ASAP!! Thanks
Old Mar 6, 2019 | 05:07 AM
onecoolee's Avatar
onecoolee
I have the 03 FSM, and I copied a page for you, but the uploading/attachment feature here is not working right now, so I couldn't upload the image... sorry.
O2 sensor
B = 4
P/L = 3
B/OR = 1
R/B = 2
Connector pinout (latch is on top):
( 3 1 )
( 4 2 )
I hope that helps....
Old Mar 6, 2019 | 06:16 AM
Heel Til I Die's Avatar
Heel Til I Die
I posted the images from the FSM in this thread (just in case the above explanation doesn't clear things up):
https://my350z.com/forum/maintenance...l#post10986324
aarrgghh
May 1, 2022 11:04 AM
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
nanotech
Oct 2, 2015 05:02 AM
