Anyne who hears clicking from the wheels!
Old Jun 23, 2003 | 08:34 PM
syf0n's Avatar
syf0n
Thumbs up Anyne who hears clicking from the wheels!
I had my car examined after I started to hear a clicking or ticking sound from my rear wheels last weekend. I would hear the noise when I accelerated, and it quickly got worse -- would hear 5 or 6 "clicks" when I accelerated or shifted gears!
Turns out some bolts on the axle became corroded. This leaes me with some other unanswered questions (i.e. wtf nissan makes bolts out of) but I wanted to post because I saw another post where someone had this problem but couldn't figure it out so I thought I'd post up the solution the local dealer came to.
cheers,
richard
Old Jun 23, 2003 | 08:41 PM
AmyCroft's Avatar
AmyCroft
Smile Re: Anyne who hears clicking from the wheels!
Syfon:
I apreciate your input... But unless you are doing doughnuts in the ocean... I had not heard of this perticular issue.. Exactly where on the Axle (Rear I Asume) is the "Clicking come from?"
Cheers Amy -
Hopefully, this diagnosis has been placed in the NNA - Database?
cheers,
richard
Old Jun 23, 2003 | 09:37 PM
syf0n's Avatar
syf0n
I was wondering about this as well. I asked and they said moisture was most likely. I live in New Orleans, and we had some pretty severe rain last week. A storm came up from mexico I think. My car was by no menas flooded but there may have been enough water to have an effect since there would have been a lot of splashing as I drove around (avg rainfall was like 3 or 4 inches around town, some standing water in lower streets was a few feet)
That is all I can think of...
Old Jun 23, 2003 | 10:04 PM
AmyCroft's Avatar
AmyCroft
Smile Er Roger - Thanks
Thanks - I understand..
Cheers Amy -
Old Jun 25, 2003 | 05:38 PM
JonsilvZ's Avatar
JonsilvZ
I had the same clicking noise. Went to get it serviced and they just tightened the axle nuts. Never came back, I put over 1500miles.
Old Jun 25, 2003 | 06:38 PM
articfury's Avatar
articfury
Charter Member #55
I have the exact same noise. The car is going in tomorrow for this and some other issues.
Thanks for the info.
JD
Old Jul 24, 2004 | 06:25 PM
surms's Avatar
surms
my car has the same problems and Nissan said it does deal with the rear axle... they said there's a new bearing configuration and its gonna take a while to fix... I thought a bearing problem would cause more of an exhaust-like hum... Any input?
Old Jul 25, 2004 | 12:02 AM
syf0n's Avatar
syf0n
Try telling your dealer that a friend with the same car & problem found out from his dealer that it was what we said above. Might cut down the time required to fix it, although most dealers disregard everything the customer has to say unless it comes through official channels...so it really is a shot in the dark. Depends how nice the guys at your dealer are
Also, thanks for adding your comment to this thread which is more than a year old instead of starting a new topic to further dilute things. I noticed that this is your first post, and I appreciate you making use of the search function.
What year is your car, 04, 04, 04.5?
Old Jul 25, 2004 | 12:24 AM
Wicked4u2c's Avatar
Wicked4u2c
LOL I have the same problem... But I noticed that clicking sound when I put on my aluminum lug nuts? I figured because because they are aluminum they do that because I'll be done driving the car and if I drive it hard or brake a lot when I leave it parked I hear those clicking sounds, like metal is expanding... Haven't really paid to much attention to this because it hasn't bugged me that far yet...
Old Jul 25, 2004 | 12:26 AM
Wicked4u2c's Avatar
Wicked4u2c
https://my350z.com/forum/showthread....threadid=82465
Seems like its the same thing??
Old Jul 25, 2004 | 01:38 PM
syf0n's Avatar
syf0n
This is not the same thing...I have had both issues. The clunk in the front suspension is only when you cut the wheels and go forward or in reverse at low speed, like parking in a parking lot. The clicking or ticking is a much different sound and doesn't come from the front control arms.
Old Jul 25, 2004 | 08:30 PM
boxsterkiller's Avatar
boxsterkiller
The clunking sound from the front is coming from the upper control arm bolts that are loose they have to loosen one whole turn and torque to spec. and the rear click sound are the rear axle splines that had to be cleaned , lubed and retorqued to spec. Good Luck these are just a few problems with the Z. Look at the TSBs at www.infinityhelp.com , click 350z, make copy take to dealer.
Old Jul 25, 2004 | 08:32 PM
boxsterkiller
www.infiniti.com sorry.
Old Jul 25, 2004 | 08:34 PM
boxsterkiller
Thats www.infinitihelp.com I'm all high right now sorry
Old Jul 31, 2004 | 07:32 AM
mpol99's Avatar
mpol99
I have the clicking a LOT it annoys the hell out of me. Thanks for info!!!!
Old Jul 31, 2004 | 07:55 AM
spinninbackfist's Avatar
spinninbackfist
Had the clicking once they greased and tightend the axle, 2,000 miles later you guessed it, it's doing it again.
Old Aug 1, 2004 | 07:13 AM
M23's Avatar
M23
can anyone tell me where exactly are the bolts that need to be tighten and lube located??
the mechanic was having a hard time locating them...
thanks
Old Aug 5, 2004 | 08:55 AM
Zbigdoggy's Avatar
Zbigdoggy
Had the exact same problem 5k ago, they ended up scraping rust off of the rear axle - all better now...
2003 performance coupe 18K
Old Aug 14, 2004 | 11:19 AM
jaa1755's Avatar
jaa1755
There is a service bulletin addressing this exact issue - go to the website mentioned above - www.infinitihelp.com
Old Aug 16, 2004 | 12:37 PM
PAZee's Avatar
PAZee
I have had the same problem. CLicking at 16k miles from the rear, underload. Dealer says the parts on on back order, it's been 3+ weeks and the parts department says they are awaiting nissan to release new parts/redesign.
