how do i change my spark plugs?
Old Mar 18, 2008 | 10:24 PM
350z_Showoff's Avatar
350z_Showoff
Originally Posted by zpaaji
+1
Changing spark plugs is one of the easy tasks that you will take on the Z. Only took me about half hr to do mine.
Holy ****. How did you do it 30min....Took me 1 hr and half.
5min-remove strut bar
30min-remove upper/lower plenum.
10min-remove coil packs
20min-remove stock plugs and instal new ones.
30-45min-reassamble the plenums and strut bar
Old Mar 18, 2008 | 11:26 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/319012-diy-spark-plugs-change-huge-pics.html
^ Have you looked at my DIY?
You don't have to remove the plenum, but it makes it easier. Also, once you get used to uninstalling and installing these things (after a while, it becomes second nature), it really doesn't consume that much time.
Old Mar 18, 2008 | 11:27 PM
SuperBlack350z's Avatar
SuperBlack350z
there was no need to remove the plenums.
Old Mar 18, 2008 | 11:41 PM
350ZTheStandard's Avatar
350ZTheStandard
Originally Posted by NA&CH
is that a safe link???
getting ready to do my plugs along with my spacer and then some blinker fluid
Chris
This blinker fluid drain & fill proces is best if left to the NiSSan service pros, especially if you are going to be using the JDM 30 weight blinker fluid. While I am always excited to see a owner doing the service work on their own vehicle. I personally have had to find the threshold of my expertise the hard way while rotating the 30 weight blinker fluid. Besides the specialized tools and technical support required, most mechanically inclined owners leave this to the qualified NiSSan stealerships of their choice.
Your results may vary
Old Mar 19, 2008 | 07:59 PM
j3dz's Avatar
j3dz
I agree...no need to remove the plenums...just did mine last week....im not very mechanically inclined so it took me 1 1/2 hours plus 2 beers....better than $250 the dealer chargers for the job....Fcking stealerships!
Old Mar 19, 2008 | 08:01 PM
SuperBlack350z
is that what they really charge? damn thieves. Glad you did it yourself.
Old Mar 19, 2008 | 08:08 PM
j3dz's Avatar
j3dz
Yeah man me too...felt so good just knowing the stealerships wasn't going to stick a broomstick in my butt! And found out how to do it in the DIY section...this site is so awesome! so much info!
Old Mar 20, 2008 | 08:52 AM
Ztalker's Avatar
Ztalker
Originally Posted by SDEd
I just had the timing belt changed out and the transmission flushed.
didn't you also change the 03 air in your tires with 08 ?
350z82
Oct 1, 2015 06:25 PM
