Window TSB fixed the grease marks, BUT...
...now I have another problem. Every time I roll the window up (one touch), it automatically comes back down half way. Looks like the safety function of the window is activating after window is completely up. Scared me the first time it happened, I wasn't sure what the hell was going on. Then I manually held the window up button until it closed and for a couple of second longer. This seems to keep the window up. Doesn't happen all the time, more sporadic than anything else. Good news is that it happens often enough for the dealers to be able to replicate the problem. I have an appointment to get this looked at on Monday. I'll keep you posted. -m
That sucks. I took my car in for the TSB and they could only do the driver side as they made a mistake and didn't order the passenger side replacement part.
My window functions normally but there is still a slight grease streak. It's very minor but, nevertheless, still there. I have to bring it back to the passenger side so I will bring this to their attention.
Is your streak completely gone?
I have not done the window streak tsb, but my driver window has started doing that as well. Only on a few occasions, say 1 out of 5 times. Let us know if they fix it and I might take mine in to get the grease streak fixed at the same time.
I've had my windows fixed (passenger side twice, grease came back). The hardest part of the repair for the technician is to get the window aligned properly and the window positon controller synced right. They've always done mine correctly but the mechanic that does it is a especially trained for doors & windows.
Re: Window TSB fixed the grease marks, BUT...
[QUOTE]Originally posted by MacGuru
[B]...now I have another problem. Every time I roll the window up (one touch), it automatically comes back down half way.
EXACTLY why I will NOT have them take apart my door! A cotton cloth and window cleaner will be fine until the grease dries up!!
Too many things that can go wrong inside the 350Z door!!!!
Peaze!
Peaze!
Well, I got the Z back with windows fixed. What was going to take all day, only took them 3 hours. Very impressive considering they always take an entire day to work on the Z. Thanks to Tom @ Koepel Nissan.
Problem has been eliminated, windows work fine now and no grease marks detected. I'll update in a couple of weeks.
Cheers. -m
Cheers. -m
...Every time I roll the window up (one touch), it automatically comes back down half way.
I don't mind cleaning my window streaks, they are barely noticable. My car is rattle free, and after hearing storie about numerous rattles I don't want Nissan taking my car apart. So the whole auto-up thing isn't bothering me too much either. I would imagine it is pretty complicated aligning the window since the move everytime you open and close the door.
If they fix it, let us know.
I've been told that it is simply a matter of resetting the trip meter - this according to Nissan. I think they're on drugs to
suggest this as the solution, but I have yet to have the problem.
Inquired because a few people were having the problem here.
Try it.
Try it.
Boots patrol
Exterior
11-07-2015 12:26 PM
