strange problem...engine randomly shutting off
Old Mar 20, 2008 | 05:01 PM
JonnyRod's Avatar
JonnyRod
Default strange problem...engine randomly shutting off
This has happened to me twice now. I'll be in third gear...holding it around 30mph...and my engine will just shut off. All the lights on the dash come on. And when i crank it back over, it starts right up with no hesitation. My SES light is not on, and it is stock under the hood besides a k&n intake.
Any advice? Could the car be throwing codes right now even though my warning light is not on?
Catchmeifyoucan's Avatar
Catchmeifyoucan
did you just put in any mod?
Old Mar 20, 2008 | 06:56 PM
JonnyRod's Avatar
JonnyRod
nope. everything has stayed the same for over 6 months
Old Mar 20, 2008 | 09:50 PM
Willowns's Avatar
Willowns
Check the battery terminal? It might be loose and might have moved around when you hit a bump! And if its dirty clean it off really good with a wire brush!
Old Mar 21, 2008 | 04:26 PM
JonnyRod's Avatar
JonnyRod
if it was the batter terminal loose wouldnt the lights turn off too?
Old Mar 21, 2008 | 08:50 PM
Willowns's Avatar
Willowns
Well thats a good point. lol. Just a suggestion though...hmm. sorry
Old Mar 22, 2008 | 06:19 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
No check engine lights?
Old Mar 22, 2008 | 11:51 PM
JonnyRod's Avatar
JonnyRod
Correct. nothing.
Old Mar 23, 2008 | 06:30 AM
captj3's Avatar
captj3
Check the car for stored codes. Sometimes it doesn't throw a cell light. I've had it happen a few times.
Old Mar 23, 2008 | 10:29 AM
maxpowers's Avatar
maxpowers
A long shot, but I had this problem in an old car and it was the ignition switch (behind the key lock cylinder)
Old Mar 23, 2008 | 01:56 PM
JonnyRod's Avatar
JonnyRod
ok thanks guys i'll go to autozone
Old Mar 25, 2008 | 08:13 AM
1sikz31's Avatar
1sikz31
if the check engine light is OFF... autozone CANNOT check it... their code readers only check for codes that are ON... no stored codes...
*i work there.
Old Mar 25, 2008 | 03:24 PM
Frank@MtroNiss's Avatar
Frank@MtroNiss
Default stalling
are you coasting at 30mph?..if so.. check the idle learn it may be idling to low and the iac is not picking it up quick enough.
Old Mar 25, 2008 | 04:46 PM
JonnyRod's Avatar
JonnyRod
*i work there.
ok thats what i had thought. thanks alot saves me a trip
Old Mar 25, 2008 | 04:47 PM
JonnyRod's Avatar
JonnyRod
to be honest i cant remember...i'll pay better attention for when and if it happens again
Old Apr 22, 2008 | 08:10 PM
oneradtek202's Avatar
oneradtek202
my car JUST did the same thing and its happened twice. ! I also have a K&N intake on my car too being the only mod i have. Any correlation between teh mod and the stalling? im gonna go get my ecu read for stored codes to see what is up on thurs
ill keep u posted
Old Apr 23, 2008 | 10:55 AM
Billhyco's Avatar
Billhyco
IAC could be bad. I don't think they will throw a code either.
Old Apr 24, 2008 | 08:45 AM
oneradtek202
ok had my z in to a nissan dealer and they looked into my computer and there were no stored codes so im kinda at a loss for why my car did this, only 2 times so far, well see if it keeps happening
Old Apr 25, 2008 | 09:45 PM
oneradtek202
ok payed attention to when this stall happens.....its when im in neutral between gears coming to a stop, im thinking idle air control for me. Where is that located and how much to replace it?
Old Apr 26, 2008 | 06:56 AM
Corradoslc7's Avatar
Corradoslc7
The Nissan 350z doesn't have an IAC valve; it uses a system called ISC (Idle Speed Control), which uses the dbw throttle body to control the idle speed. If you really think something is wrong in that area, then the Electronic Throttle Control Actuator is the area you want to check. I would start by checking for a vacuum leak first and then go to the ETCA.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
lapham3
Oct 7, 2022 03:15 PM
AbyteZero
Sep 22, 2015 09:17 AM
Bigsyke
Sep 11, 2015 06:19 PM
