Help me fix my broken passengers seat.
Old Mar 20, 2008 | 08:23 PM
dudegetalife's Avatar
dudegetalife
Default Help me fix my broken passengers seat.
The seat goes forwards just not back.
they are the leather premium heated seats, is their anyway that i can fix this myself so i have access to the place where i can lock my stuff in?
Old Mar 20, 2008 | 09:46 PM
Willowns's Avatar
Willowns
your best bet is to push the button down and then back, dont be scared to use a little force....This happend to me a couple of days ago and i just said screw it and mashed it down and back and it worked! i had to this a few times but now its back to normal...weird...but I am warning....take your time and try everything...dont break you seats cuz of me!
EDIT: Also try pushing the seat back as you jiggle the switch around!
Old Mar 20, 2008 | 11:01 PM
anotheraznguy's Avatar
anotheraznguy
or if you are still under warranty send it to the dealer.
Old Mar 21, 2008 | 05:53 AM
dudegetalife
not under warranty bought it used
Old Mar 21, 2008 | 06:12 AM
Russ@Z1's Avatar
Russ@Z1
I've occasionally had a similar issue with my driver's seat.
My solution was a couple back and forth motions on the switch which solved the problem. I'm only assuming there's enough dust/dirt/buildup in between the contacts in the switch that needs to be cleaned.
That may not be the case with your seat, but it's worth a shot and a cheap/free repair option.
Old May 6, 2008 | 04:34 PM
nautox's Avatar
nautox
I have an 03 Touring, seat goes forward, no back. I put straight 12V to the motor and it moves. I reverse the polarity of the Voltage, it moves the other direction. So obviously the motor works fine. (note the motor is nicely in the front right side on the passenger seat and the connector is right there)
I got the passenger seat switch yesterday. And now the seat goes back and forth no problem.
Took the 4 bolts out that hold the seat down. Tipped it forward to unplug the 2 wire harness connectors. Yanked it out and set it on its side (headrest resting on the rocker panel so it didn't get dirrrty. Used a screwdriver to press the tabs on the old switch to get it out. The tricky part was getting the harness past the seat frame, barely enough room to get it through, hint: have the tab piece that sticks out pointing up to snake it through the less than an inch gap. Then reverse the process and your done. I heard these switches are junk, but luckily under $100.00 and 20 minutes labor on this one.
Good Times.
Old Aug 23, 2008 | 01:25 AM
BlueDragonZ's Avatar
BlueDragonZ
So basically replace the switch, I'm assuming this issue solves the driver side as well? I can't recline the seat forward only back on the driver seat.
Uriyo_
Sep 8, 2021 08:46 AM
Rev_Night
Nov 7, 2020 06:00 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
samansharif
Sep 25, 2015 12:31 PM
