Just change accesorry belts, and spark plugs
Old Apr 1, 2008 | 06:27 PM
syndacit's Avatar
syndacit
Default Just change accesorry belts, and spark plugs
I just changed them and now I have a service engine soon light.
Could it be, because I slipped and moved the throttle plate a little? should I disconnect battery or do the throttle restart and see if that works?
Oh and did forget to reconnect the TPS and started the car twice.
Should I take it to a dealer in the morning and have them check it out?
(I did also have oil on my SPark plug on #6 cylinder )
Old Apr 1, 2008 | 08:00 PM
syndacit's Avatar
syndacit
I'm keep bumpin till someone responds cause i dont want to be a ***** and do a repost
Old Apr 1, 2008 | 08:22 PM
SuperBlack350z's Avatar
SuperBlack350z
just reset the car and see what happens.
Old Apr 1, 2008 | 08:33 PM
syndacit's Avatar
syndacit
I've disconnected the negative battery cable.
Should I leave it disconnected over night?
Cause it seems I cant do the throttle reset procedures correctly.
If I cant, its still drivable. I can go to a dealer in the morning
Old Apr 1, 2008 | 08:36 PM
SuperBlack350z
yeah, usually what i do is take off both terminals just in case...go back in the car, press the brake pedal like ten times to make sure all the power is out, then put it back on in the morning.
Old Apr 2, 2008 | 08:54 AM
syndacit's Avatar
syndacit
left neg terminal off. Its gone. Car drives fine, and pulls hard ^.^
350z82
Oct 1, 2015 06:25 PM
