Oil on Plug, Might be valve Guide
So I talk to a guy at the dealership today about the Oil on my spark plug. It might be one of the valve guides.
AAARGGGG
cause the oil wasnt on top of the plug where it connects to the coil. It was on the bottom.
So it could be a gasket, or one of the valve guides. Maybe its time for a stronger engine :P instead of a SC.
Any thoughts on what it could be.
AAARGGGG
Originally Posted by blasian
It's probably just your tube seals leaking on the valve cover...
Was it on the plugs in the rear?
Originally Posted by syndacit
It was on the threading and near the tip where spark occurs
oh ok, I get it. I'm kind of slow sometimes, specially when I have a headache.
would make sense. So its probably the seal thats bad and allowing oil to get on the thread of the spark plug then.
Okay so when replacing this what all do I need to replace? Is it just the Valve Cover? or is it a whole assembly? final question should I go to a dealership or know any place online that I can order it?
You should only need both valve covers (if both sides) and both valve cover gaskets and all the other gaskets that have to be replaced from the things you remove.
I'm looking at all data.
I would just need, New valve covers, the Gaskets, and 6 new o rings. Lubrication/oil and such too.
Anything I should be careful about when doing this?
It's rather time consuming and more of a PITA than it should be but in a sense... its not too bad.
