any Nissan techs?
My cars been driving wierd for a while now and I drove to the local dealer to get it checked out. He didn't find any codes, but he looked at a diagnostic reading. Suposedly if that reading is below 95 the MAF is bad. Mine was at 85. I switched out the MAF with my father's Infiniti to troubleshoot that. I still had the problem. I figured since it wasn't the MAF itself it might be connected to it, so I was going to check the voltage to the MAF. I can't find what it's supposed to be though.
From what I keep hearing from you guys, Nissan stealerships do diddley squat
for most of us! I guess finding a nearby mechanic with diagnostics equipment
is the way to go. Then, again, it's h-a-r-d finding an honest mechanic (???).
Politicians, lawyers, mechanics...I dunno, man, I dunno...
I also checked the voltage on terminal 1 of the throttle control earlier and got 5.11, when it's supposed to be approximately 5. I just checked the continuity from terminal 5 to engine ground as said by manual and got around 13.5 ohms. Is that good? They didn't give a number in the manual.
The big thing is terminal 69 (TPS 2), as indicated by the CEL codes. It's reading over 12v when it's supposed to be under 4.75. In the manual it says if no go on that to replace the throttle control actuator. I already did that, when I switched the throttle body, right?
Also I'm confused as to where the TPS are anyway? It looks like the manual was showing the TPS being in the throttle actuator, but I thought they were seperate.
Also 03Zilverstone did you perform the Throttle Valve Closed Position Learning and Idle Air Volume Learning procedures? Both must be performed everytime the throttle control actuator is disconnected or replaced. If not you may have actually solved your problem, but the car wasn't able to fully recognize the good throttle control actuator from your dad's G.
I did those. I was going by the service manual on the sensors. And I think I may have found the problem. It would explain why I was getting too much power to the IAT and TSP, right?
https://my350z.com/forum/engine-and-drivetrain/352941-ecu-compatability.html
Originally Posted by Billhyco
gas pedal is bad
Not questioning you. Just asking what your reasoning is, since to me it would point to a short were the water got to the connector at the ecu.
Originally Posted by surfcity40
did you check what the codes meant at the other site?
What do you mean? I checked the manual that came with my OBD-II reader and my 350Z service manual.
Just last weekend at VIR had the same
PO123 and PO223 codes
Description of vehicle obd trouble code P0123 - Throttle Position Sensor/Switch A Circuit High Input.
P0223 - Throttle Position (TP2) Sensor Circuit High Input
Called my shop foreman buddy - ASE Nissan tech, he says change the gas pedal so I did. Once the pedal was off we did check for power at the plug and if I remember right the manual says approximately 5v at pin 6. We had approximately 5.2v so we replaced the pedal assembly. Cleared code, problem solved.
