tingling sound
Old May 20, 2008 | 06:11 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Default tingling sound
I hear tingling sound when accelerating under the car but not really sure exactly where its coming from.
Old May 20, 2008 | 06:43 PM
Maybe the anti-tinkle valve is jammed with back pressure?
Old May 20, 2008 | 06:46 PM
CSF's Avatar
CSF
not much to work with there...is it loud? what other conditions (all acceleration, hard acceleration)? mods?
Old May 20, 2008 | 07:08 PM
Ilov350ZEE's Avatar
Ilov350ZEE
all acceleation. I just put on Nismo catback exhaust but the sound was already there before. I have JWT PC, and AAM plenum i think the sound have NO connection with the sound im hearing.
Old May 20, 2008 | 07:09 PM
Ilov350ZEE's Avatar
Ilov350ZEE
Old May 22, 2008 | 03:33 AM
slanteyez's Avatar
slanteyez
im 100% sure its axle click
Old May 22, 2008 | 02:37 PM
CSF's Avatar
CSF
tingling = clicking?
i was imagining a ringing sound
Old May 23, 2008 | 10:33 AM
NiZmo&Mo's Avatar
NiZmo&Mo
Default Sound Tingling
"I think the sound have no connection to the sound I'm hearing."
That was beautiful man, thanks
Old May 24, 2008 | 04:09 PM
slanteyez's Avatar
slanteyez
does it sound like a bunch of marbles in a bag shaking?
Old May 24, 2008 | 04:12 PM
surfcity40's Avatar
surfcity40
Under what conditions are you able to accelerate under the car. I need more info to offer an appropriate response.
Old May 24, 2008 | 04:14 PM
surfcity40's Avatar
surfcity40
That would be the cat.
Old May 25, 2008 | 07:03 AM
pnoy350Z's Avatar
pnoy350Z
i get that too
Old May 25, 2008 | 07:13 AM
Ilov350ZEE's Avatar
Ilov350ZEE
yes something like that
i dont hear it all the time but when i do it is accompanied with acceleration hesitation.
Old May 25, 2008 | 09:48 AM
BallZdeepNYC's Avatar
BallZdeepNYC
its the cat im having mine changed under warranty this week
It sounds like metal tingling under the car if they lift your car and bang on the cat youll hear it if you are inder warranty its covered.
Old May 25, 2008 | 09:59 AM
Spork's Avatar
Spork
Tingling as in a hollow resonance sound? It's coming from the metal compartments behind your seat and the metal part that goes downthe center of the car. Sound deadening fixes it.
Edit: Nvm, I'm thinking of a different sound.
Old May 25, 2008 | 10:22 AM
Z04's Avatar
Z04
and i am 100% sure you are wrong since it was the 2003-2005 that had axle click, and he owns a 2006
Old May 25, 2008 | 10:24 AM
Z04's Avatar
Z04
also, check here
http://www.nissanhelp.com/Ownership/350Z/Diagnose.htm
Old May 25, 2008 | 01:27 PM
BallZdeepNYC
its the cat... like i stated before. If you are under warranty the dealership will order and fix it for free. I have axle click as well all gettin taken care of under warranty trust me i have every problem that happens on Z i had tire feathering, axle click (now), Cat tingling (now), and now just realizing that i have the gas gauge reading is wrong tsb so i have to get that handled, plus mushy brake pedal so has to be flushed and bled with new fluid
Old May 25, 2008 | 05:12 PM
imabug's Avatar
imabug
I've just started getting the sound and I have an '03. It's only there when I accelerate or decelerate and at around 1500rpm... at any lower or higher rev the sound disappears.. i got under the car and i could hear it from the cat to mid muffler and that's where it's at its loudest - mid muffler... does this sound like the same problem? And if not then does anyone know what it could be?
Cheers
Old May 25, 2008 | 05:29 PM
Ilov350ZEE's Avatar
Ilov350ZEE
i have an 06 w/ 23k miles. If it is the cat. whats wrong with it, and does it affect exhaust air flow like restriction?
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
