Need Help on clicking sound
Originally Posted by yeayeachriscoop
i have my car lowered and i'm hearing that clicking sound. was yours lowered when you took it into the dealership?
Originally Posted by Gingervitis526
Mine does it as well, I guess all they have to do is pull the axels, grease em up, rotate em 180 degrees then you should be good as gold. They told me they did that but it still clicks. I've been told it doesn't hurt the car in anyway, its just annoying. Not sure how true that is, either way I am going to have them look at it again for me.
My dealer just quoted $375 to fix this but I'm still under warranty. I'm currently locked in mortal combat with the dealership to get them to cover it under warranty. Of course they are saying it's a "maintenance issue".
Originally Posted by Sunger
I just got mine fixed at the dealer. All they did was replacing bolts/nuts/washers of the rear axle and the clicking sound went away
But they didn't say anything about greasing the axle.
But they didn't say anything about greasing the axle.Anyone else have any info to support that? That makes sense to me, because the axle bolts to the output hub coming out of the diff. It seems like if those bolts were stretched a bit, it would allow the axle to turn very slightly when going from reverse to 1st, thus making the "clicking" sound.
If that's all it is, then I would rather replace them myself.
My 2003 just hit 61,000 miles, so the 5yr/60,000 warranty is out the door...
-Tim
I have this and a friend with a G has it too.
I thought it had something to do with the Brembo brakes and the hand brake.
Must have this checked out.
The dealer will probably not do anything for me because of the mods, bastards.
Took my 2004.5 Z with 38k miles for this TSB fix and I was told that they would have to charge my a $90 labor fee to have the clicking issue resolved. Is there a phone number at Nissan that I can call to have this labor fee confirmed? I might just file a complaint.
Thanks
Thanks
So I hang up and call the dealer. They don't know of course and said they never had one - even though they fixed mine
I said I will just drive it until the axle breaks off
Bunch of worthless people
Justin100
Nov 29, 2015 03:58 PM
