The answer to the alignment problem.
Old Jul 17, 2003 | 05:11 PM
redfox's Avatar
redfox
Default The answer to the alignment problem.
***** SORRY GUYS ******
I was slow and didn't read the previous posts. Was trying to be helpful.
Old Jul 17, 2003 | 05:37 PM
redfox's Avatar
redfox
Ahh what the hell, here it is anyway, AGAIN.
My dealership was not able to do alignment on my car because its too low for their machine. So after looking at my tires and see what I mean by feathering, the tech spent a few worthwhile minutes on the phone with the nissan head office. The official word is that the problem is with the TOE at the front.
Spec says anywhere from 0.00 to 0.04 degrees. But Nissan says you HAVE TO SET IT TO AS CLOSE TO 0.04 degrees as possible. So basically, it's not a range. You HAVE to have it at 0.04. And that should solve the tire feathering problem. But how the heck do you keep it there?
If anyone has more information, please add.
Old Jul 17, 2003 | 06:00 PM
jackwhale's Avatar
jackwhale
Just had my car alligned after new tires. Here are the specs which the shop obtained.
FRONT WHEELS
Camber Minimum -1 o 20' (-1.33o)
Nominal -0 o 35' (-0.58 o)
Maximum 0 o 10' (0.17 o)
Left and right difference 45’ (0.75o)
Caster Minimum 7 o 35' ( 7.58 o)
Nominal 8 o 10' (8.17 o)
Maximum 8 o 55' (8.92 o)
Left and right difference 45' (.75 o)
Kingpin inclination Minimum 4o 20’ (4.33o) Nominal 5o 05’ (5.08o)
Maximum 5o 50’ (5.83o)
Toe in Minimal 0 mm ( 0 in)
Nominal 1mm (.04 in); Maximum 2mm (.08 in)
REAR WHEELS
Camber Minimum -2O 05’ (-2.08O)
Nominal -1o 35’ (-1.58o)
Maximum –1o 05’ (-1.08o)
Total Toe-in Minimum 0.2 mm (0.008”) for 17” tire
Nominal 1.0 mm (0.039”)
Maximum 1.8 mm (0.071”)
Minimum 1.1 mm (0.043”) for 18” tire
Nominal 1.9 mm (0.75”)
Maximum 2.7 mm (0.106”)
I see that my post did not pick up degrees and used a 'o' instead.
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
