What is the tire pressure??
Old Jul 18, 2003 | 12:40 PM
Bahraini350Z's Avatar
Bahraini350Z
Question What is the tire pressure??
What is the tire pressure reading I'm supposed to get on the computer??
Old Jul 18, 2003 | 01:00 PM
Buub's Avatar
Buub
Could you please be more vague?
Old Jul 18, 2003 | 01:53 PM
Bahraini350Z
I mean the reading on the monitor!!! coz I keep reading 36psi and I think it's on the high side.... this is why I posted this thread, to ask the experts
Old Jul 18, 2003 | 02:50 PM
jackwhale's Avatar
jackwhale
Buub--
The manual, as I recall, says that front and back should be 35 lb when cold. This means that pressure will increase as the temperature of the tire increases.
I also found that one of my pressure sensors reads 1 lb high. The rest are right on target. Initially I had difficulty believing that the sensors could be that accurate.
Old Jul 18, 2003 | 10:21 PM
Bahraini350Z
thanx
Old Jul 18, 2003 | 10:45 PM
AmyCroft's Avatar
AmyCroft
Default Re: What is the tire pressure??
Hello
How many 350Z's do you have in your Country?
Thank You in Advance..
Cheers Amy -
amy@amycroft.com
Old Jul 19, 2003 | 05:16 AM
Bahraini350Z
we have 4 350Zs and one G35 and all the cars were imported from the States and Canada!! the dealer did not bring them yet
TC
Old Jul 19, 2003 | 05:20 AM
03 Z for ME's Avatar
03 Z for ME
OK here's an **** question for you all... IF the manual says 35PSI cold, just how cold is cold? I mean if I have the Z garaged overnight and check the pressure "cold" in the morning, I might get 33 pounds, however if it's been parked outside and hasn't been driven (tires still "cold") I might get 35 pounds. In the dead of winter I'll see maybe 32 PSI...
Maybe for us **** folks (like myself) NISSAN should say "Cold tire pressure, when not parked in direct sunlight, with an ambient temperature of 72 degrees, having not been driven in the past 24hrs, should be 35 lbs...
Old Jul 19, 2003 | 07:40 AM
jackwhale's Avatar
jackwhale
Its simple we just wait 10-15K miles and see if the tire wear is uniform across the tread surface.
I'll bet that no one has determined whether 35 cold or 32 colder makes any difference in tire wear. However race/autocross drivers do regulate their air pressure within a pound or two to gain maximum tire traction.
Old Jul 19, 2003 | 08:47 AM
Buub's Avatar
Buub
"Cold" means at ambient temperature. I.e. the temperature of the tires after sitting for several hours without being driven. Taking the temp in the morning before you drive probably works best.
The pressures are actually on the inside cover of the flip-up console compartment, under your right elbow.
Yes the pressure should change as you drive around. It should go up as the tires warm up. If it's not changing much you're not driving hard enough. :-)
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
