Help! A/c Not Working!!!
Old Jun 24, 2008 | 11:13 PM
unkn0wn ryder's Avatar
unkn0wn ryder
Default Help! A/c Not Working!!!
well my a/c isnt working now..... i went two months with a hole on my a/c w/o knowing..... but when i finally fixed the leak and refilled it it wont blow cold.... all i got was hot air...
here's what i've done in the process of fixing it...
1. tried the liquid seal ... but turns out the hole was too big to be filled....
2. made a line with aluminum and some type of aluminum sealant.... then filled it w/ freon...
no longer have a leak but a/c just blows hot air...
any suggestions?
mike
Old Jun 25, 2008 | 01:04 AM
z2g's Avatar
z2g
did you vacuum the unit before filling with freon? does compressor turn on?
Old Jun 25, 2008 | 03:49 AM
magna750's Avatar
magna750
Did you "over service" the unit? Too much refrigerant is just as bad as too little.
Old Jun 25, 2008 | 04:53 AM
KornerCarver's Avatar
KornerCarver
Are you using the term "freon" generically or did you really put freon in your air conditioner? I believe all cars since 1994 use R-134A as their refrigerant.
I would suggest taking the car to an air conditioner shop and having them repair it.
Les
Old Jun 25, 2008 | 09:29 AM
unkn0wn ryder
yes i used r134a
the compressor kicks on and takes the the freon when i filled it.... and still no cold air....
Old Jun 28, 2008 | 12:09 AM
z2g's Avatar
z2g
Did you take apart the dash recently?
Old Jun 28, 2008 | 03:42 PM
unkn0wn ryder
nope.... havent done anything to the car in a while except get new rear tires...
Old Jun 28, 2008 | 04:42 PM
35Z's Avatar
35Z
Thumbs up No Cold Air - Test
Did you perform the Auto active test of the IPDM E/R to ensure the a/c compressor is working properly? The IPDM E/R auto active test sends a signal to the following systems:
a/c compressor (magnetic clutch)
cooling fan lights (headlights,tail lights)
front wipers
rear window defogger
When in auto active mode, these systems are tested three times. Check your year's 350Z service manual for specific details on how the initiate the auto active test.
Old Jun 29, 2008 | 06:35 PM
Eazzy's Avatar
Eazzy
There are no quick fixes with A/C. Leaky hose must be replaced. Accumulator must be replaced. System Must be flushed. System must be vacuumed. Oil must be added and system is ready for charge.
Old Jun 29, 2008 | 06:46 PM
eltness350's Avatar
eltness350
The Untouchable
i have a complete ac system off of my 03z that i dont use...was taken off when the car only had 25k....so u know if u cant fix it and need anything...
Old Jul 4, 2008 | 10:12 AM
35Z's Avatar
35Z
Default A/C Fix
Did you fix your Z's a/c?
Old Jul 5, 2008 | 03:55 PM
unkn0wn ryder
never got a chance to fix it yet since im in hawaii for vacation.....
Old Jul 11, 2008 | 02:37 PM
unkn0wn ryder
how much you want for it?
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
