Window switch getting a bad connection?
Old Jul 2, 2008 | 11:07 AM
Brrcats's Avatar
Brrcats
Default Window switch getting a bad connection?
So I've been walking out to my car the past couple of days and I roll down the window using the keyfob. The drivers side window doesnt go down all the way and then its stuck there, and cant be rolled up or down using the switch inside the car or down using the keyfob. I usually bang on the door a little and it will roll down the rest of the way in a minute or two.
This happened yesterday on the way to the gym and it wouldnt roll up or down at all after it got stuck. so the whole way home I had the window cracked with the airconditioning on. not a huge deal, but I dont want to be stuck like that when it rains.
So I assume I'm getting the window motor problem and that soon a couple hundred dollars will be leaving my wallet. Just for curiosity I go out and try to roll the window up using the key in the door method. To my surprise it works immediately.
So now I'm thinking its not the motor, but a bad connection maybe.
has anyone had a similar problem?
Old Jul 2, 2008 | 11:48 AM
hndumafia's Avatar
hndumafia
Sounds like the motor to me, based on it starting to work again from the banging on the door. Mine used to be the same way. No idea about why it works fine when you put the key in the door though. I don't remember if that is how mine was or not.
You can pick up a motor from autozone for around $130 and it has a lifetime warranty.
Old Jul 2, 2008 | 11:49 AM
blasian's Avatar
blasian
VO has a thread to clean the window motors. May want to try that first before buying new motors.
I cleaned my passenger side over two years ago and it still works.
Old Jul 2, 2008 | 07:44 PM
350z_Z33's Avatar
350z_Z33
Happens to me to, it gets stuck...usualy i push the window down and it starts workin...it sucks when it gets stuck while its all the way down :O i gotta slam the door sooo annoying
Old Jul 3, 2008 | 04:17 AM
Brrcats's Avatar
Brrcats
Originally Posted by 350zeemy
dude i got the same problem!! its still there i dont even use my drivers side window. but what happened with mine is that one of my friends ran up to my window and his stupid a$$ pushed the window back down while it was rolling up. and 2 weeks later it started doing that. also sorry but not trying to hijack your thread, but my passenger side window rattles when its rolled down, and you shut the door, but when its rolled up it doesn rattle when you shut the door.
yup, mine rattles a little bit too.
i'll try to look up the cleaning method first, because I really dont think that there is an issue with the motor, but the connections to the motor, banging doesnt really work, it worked a couple times, but I think it was a coincidence as it hasnt worked recently.
well it looks like I have a project over the weekend.
Old Jul 3, 2008 | 05:49 AM
MUZZY's Avatar
MUZZY
OMG I just got this problem 2 weeks ago!
It gets stuck in down position and I cant roll it up, I slam the door sometimes and then it works but now it has been 2 weeks and it wont go up at all.
its frustrating,
Old Jul 3, 2008 | 05:51 AM
MUZZY's Avatar
MUZZY
I banged it and it worked a coupel times too but now it completly dosnt work like u, tell me what u figured out
Old Jul 3, 2008 | 10:34 AM
Brrcats's Avatar
Brrcats
MUZZY, try to use the key in the door method of closing the window. That worked for me the other day when the switch wasnt working.
I'm going to be taking my door apart this weekend to see if I can do anything about it, maybe use VO's cleaning method that blasian mentioned.
Old Feb 9, 2010 | 07:42 AM
vbgambini's Avatar
vbgambini
I have a similar issue. My GF 03 Z has a window problem on both sides. With my past experience with my Z i had to change both window motors. But for some reason on my GF car it doesnt seem like the motor. When I unplugged the driver side switch then re-plugged it, the windows worked. Also I noticed when I wiggle the plug while it is connected to the switch, it lights up and doesnt light up. When it is lit, the windows work. Also with the aftermarket alarm, it wont lock, but with the key fob it does. So is it a bad connection? Window motors? Window switch? Help me out guys!!
Old Feb 9, 2010 | 09:56 AM
hndumafia's Avatar
hndumafia
I had this problem on my passenger side window. The passenger door switch would lose power until messing with the wiring loom for that door. I disconnected the wiring harness where it connects from the door to the inside of the car, cleaned out both sides with air and contact cleaner, and reassembled. It has worked perfectly ever since.
Old Feb 9, 2010 | 03:13 PM
vbgambini's Avatar
vbgambini
So you mean you disconnected the clips from the door to the switch, and cleaned out the prongs inside with cleaner?
Old Feb 9, 2010 | 09:07 PM
hndumafia's Avatar
hndumafia
I think you are talking about the connector that connects to the.window up/down toggle switch that is on the door. That is not the connector that I am talking about.
If you look at the door jamb, all the wires connect to the inside of the car through a plastic connector/harness that has a rubber boot/shield covering it. If you slide back that rubber boot you can see the plastic wire harness. it has a handle sort of thing that you flip down and disconnects the harness from the door jamb and the harness it connects with that is located in the footwell. You need to get your head under the dash and look around the kick panel to see that second harness inside the car. Clean both of those harnesses and then put them back together. Should work perfectly if its the same problem I had.
Sorry if the explanation isn't the best. When you actually look at the car , it should make sense.
Old Feb 10, 2010 | 09:05 AM
vbgambini's Avatar
vbgambini
yea im going to have to look at it lol unless you have pics. but thanks for the info. ill try it and hope it works.
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
