Valve Cover oil leak
I was changing my spark plugs today and saw oil around the valve cover. Check the bolts they all seem tight. I guess I need to replace the gasket. Anyone else have this problem.
Originally Posted by SpoilsofWar
Easy fix then, just order the gasket, remove valve cover, and replace.
You'll have to remove the plenum to get to the valve covers. Not too bad but not as easy as I4s
Originally Posted by blasian
lol if it were only like a Honda.
did you guys torque to spec...? its a valve cover, you cant just crank that sh*t on there.
Originally Posted by R-TuneZ
honda maintenance is a sh*t load easier. i miss my si, i wish i could have it as my dd.
IIRC, torque specs was around 100-120 lb-in.
Originally Posted by SuperBlack350z
the service manual says to do it in two steps. First tighten all bolts in an order (sorry don't have pics of what order because it's a pdf file) at 9-26 inch lbs then go back again and do it at 65-82 inch lbs.
I had the service manual with me though
Doh, maybe I'm thinking the plenum
quick question, did you put a dab of RTV at the end of the camshaft bracket?
haha, yeah, i have to pull out the service manual all the time to make sure i'm doing it correctly.
Just experienced a similar issue. Z1 has a good deal.
https://www.z1motorsports.com/cylind...c59b20f0c3f4a6
