60K service cost question?
Old Jul 14, 2008 | 04:11 PM
cjeezy's Avatar
cjeezy
Default 60K service cost question?
Hi all,
I was wondering what I should expect to pay for my 60000 mile maintenance assuming nothing needs replaced? A list of items the dealership says need done are:
1 Balance/rotate tires (my tires cannot be rotated anyways)
2 Coolant flush
3 Install engine oil conditioner
4 Replace air filter (I have a pop charger so this won't apply)
5 check engine oil and filter
6 complete fuel system service
7 lubricate all doors, locks, hinges and chassis
8 brake inspection
9 Tranny flush
Also, does all this need done or will I void my warranty if everything does not get completed?
Thanks for the help!
Old Jul 14, 2008 | 04:39 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
That sounds pretty close to the 30K that I just had done. I didn't get air filter, had my own oil and they didn't do balance/rotate. They also did a brake fluid flush and refill and bleed. I paid $328.
Old Jul 14, 2008 | 06:10 PM
2ndname's Avatar
2ndname
That's not too bad. I paid the same amount for my 00 Celica.
Old Jul 14, 2008 | 07:27 PM
racerfreakxxx's Avatar
racerfreakxxx
for 60k i would say you would just change what needs to be done. I did my service a little early at 53k and got a full service(brake fluid, tranny fluid, diff fluid, coolant, powersteering ect)($600) and had to have my axles relubed and tightened($150)... it ran me about $750 in the end but it's worth it
oh ... do the brake pads yourself if needed and you might need your belts changed
Old Jul 14, 2008 | 07:28 PM
1. Oil and filter
2. Replace coolant
3. Replace brake fluid
4. Replace differential oil
About $200 for a reputable shop.
Old Jul 14, 2008 | 08:47 PM
~SpInNeY~'s Avatar
~SpInNeY~
belts, engine oil, transmission oil, brakes probably,
Old Jul 15, 2008 | 05:01 AM
cjeezy's Avatar
cjeezy
$750? Thats nuts! My maintenance on my BMW was cheaper than that...but I guess it kinda depends where in the country you live Anyways, I called the shop this morning once they opened and they said typically its around $350.
Thanks for all the input everyone!
Old Jul 15, 2008 | 07:24 AM
Master Shake's Avatar
Master Shake
Does anyone believe in the fuel system service that the dealers try to sell for upwards of $100???
Do they do anything other than just add a can of fuel injector cleaner and/or clean out the throttle body? and maybe the MAF?
Old Jul 15, 2008 | 01:29 PM
Bevo's Avatar
Bevo
I'm close to 30k service and I wonder if Power steering fluid needs to be flushed? In Nissan service guide, it never mentions to replace the power steering fluid, only top-off. Thanks.
Old Jul 15, 2008 | 01:37 PM
nothix's Avatar
nothix
I definitely need some new coolant and brake fluid flush
I just broke 60k and never even did the 30k maintenance.
shrug i like to DIY
Old Jul 22, 2008 | 04:24 PM
md350's Avatar
md350
I did the full 60,000 service on my Sentra a few years ago and it cost about $850. I'm just about 60k in my Z now and I don't plan on doing it again...too much money for things that likely aren't necessary. Just gonna have them do the usual, inspection and a few other things...fluid flushes and spark plugs probably.
