ECU will not reset!
Old Jul 24, 2003 | 05:58 PM
03SilverstoneZ's Avatar
03SilverstoneZ
Unhappy ECU will not reset!
Well after putting on my borla exhaust today I went to go reset my ecu. Well I used the gas pedal method and it didn't work. I need some help I am not sure if I am doing this right or not.
With the car having been off for at least 10 sec.
Turn the key to ON (not start)
Wait 3 sec.
Pump the gas to the floor 5 times whithin 5 sec.
Wait 7 sec.
Press gas to floor and hold 10 sec.
When S.E. Light starts blinking, release peadal
Press again and hold at least 10 more sec.
Done.
This is the method I am using, and once again not getting anything. Am I counting to slow or not slow enough? I am not sure. I went to the dealer to see if they could do it and they have never heard of it.
So I need some help on figuring out how to reset this thing.
Any help or suggestion would be greatly appreciated,
-David
Old Jul 24, 2003 | 08:41 PM
johnlotusboy's Avatar
johnlotusboy
You must use a watch and time very accurately!!!!
Old Jul 24, 2003 | 09:04 PM
OC_350Z's Avatar
OC_350Z
Default Re: ECU will not reset!
Wait 3 sec.
Wait 7 sec.
Done.
-David
I have never heard of that method. Where did you hear that from? I thought that if you disconected the battery for 24hr the ECU would reset.
Old Jul 24, 2003 | 11:00 PM
350zdanny's Avatar
350zdanny
24 hrs? My honda ECU reset after 30 mins. I wonder...
I also never heard of the gas pedal method until i became a member of this site.
Dan
Old Jul 25, 2003 | 03:11 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Go here: How to reset ECU
Old Jul 25, 2003 | 08:12 AM
Iezzi's Avatar
Iezzi
does disconnecting the battery for 24 hours really reset the ECU or do you have to do it this way?
Old Jul 25, 2003 | 10:41 AM
03SilverstoneZ
BONZY YOU NEVER ASSIST TO AMAZE ME
Thanks again,
-David
Old Jul 25, 2003 | 06:02 PM
zogan's Avatar
zogan
24hrs. that seems like a long time to reset the ecu. I thought you just had to disconnect the battery
Old Jul 27, 2003 | 12:12 AM
samw1978's Avatar
samw1978
It doesn't really need 24hr to reset the ecu... the ecu on my 99 Prelude SH will reset in minutes, but lots people told me the longer you disconnect the battery the better, so just unplug it and leave it over night
Old Jul 27, 2003 | 05:12 AM
cincyspider's Avatar
cincyspider
why are you resetting the ECU??
I installed a borla exhaust....do I need to do this?
Old Jul 27, 2003 | 05:18 AM
jak's Avatar
jak
Wait 3 sec.
Wait 7 sec.
Done.
-David
It took me ten times to get the this method to work. At first I thought this was some kind of joke going around, but after some practice and a watch with a second hand I got it to work.
Precise timing is critical. If you are off even a second on any step it won't work.
Keep trying.
Jeff
Old Jul 27, 2003 | 07:03 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
not sure if this is valid, but I pulled the ECU fuse by the battery compartment, and let it sit for about 30min. Put the fuse back, and went for drive. My car seems to be little stronger.. but that could be just me
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
