Noise when turn engine off
Old Sep 3, 2008 | 03:59 PM
romic00's Avatar
romic00
Default Noise when turn engine off
Hello just wondering if this is normal. When i turn the engine off with my foot off the clutch there is a weird noise like a rattleing noise. if i press the clutch the noise its gone. Also how do i get rid of the brake dust on the front wheels? new pads right? if so do i buy from the dealer or auto parts store. thanks
Old Sep 3, 2008 | 04:07 PM
surfcity40's Avatar
surfcity40
Welcome romic, but wat are you asking. the clutch rattle is normal with the engine running. Certainly if you've turned off the motor you shouldn't hear any clutch rattle unless you're confusing it with the fan hitting something.
Old Sep 3, 2008 | 04:13 PM
romic00's Avatar
romic00
no i am not confusing it. When i turn the key off (and the engine) there is a rattling noise coming from the engine or transmission. it's like trrrrrr
Old Sep 3, 2008 | 04:23 PM
Jes-Z's Avatar
Jes-Z
It's the flywheel. Totally norMAL. There's a damper on the stock clutch and flywheel setup. If you turn the car off with the clutch depressed, it won;t rattle. If you do it with out pressing the pedal you will hear the teeth on the flywheel come to a stop. Nothing is wrong.
Old Sep 3, 2008 | 04:25 PM
bloodwings19's Avatar
bloodwings19
It is normal for the rattling noise because it does the same thing in a C5 Z06. Brake dust is also normal buying new pads helps it, try Hawk pads. Later and enjoy your ride.
Old Sep 3, 2008 | 04:29 PM
maxspeed96ct's Avatar
maxspeed96ct
My g was my first rwd car and it took me a while to get used to the noises.
my buddies c6 vette and e36 m3 do it to..
I was nervus at first to, even went to the dealer. ...
Old Sep 3, 2008 | 04:55 PM
romic00's Avatar
romic00
yea thats what i need to do get used to it. Thnk you for the help.
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
