Both 12v dont work???
Old Sep 23, 2008 | 07:57 AM
dudegetalife's Avatar
dudegetalife
Default Both 12v dont work???
Cant seem to figure out why they don't work anyone have any idea? where are the fuses located so i can check if its burnt out
Old Sep 23, 2008 | 08:06 AM
VO...'s Avatar
VO...
Administrator
Did you forget to add something in your title? Please elaborate on what "12v" you are speaking of...
Old Sep 23, 2008 | 09:24 AM
dudegetalife
the power adapters where i plug in my radar detector and navi unit?
Old Sep 23, 2008 | 09:48 AM
M3ANMACHINE's Avatar
M3ANMACHINE
I had the same problem, you need a new fuse
/thread
Old Sep 23, 2008 | 07:23 PM
dudegetalife
which fuse do i replace and where no owners manual what i do
Old Sep 23, 2008 | 09:07 PM
M3ANMACHINE
open the fuse box on the left of the clutch pedal and the cover will say which fuse is the outlet fuse, and what kind of fuse it is. its a 15 i believe
Old Sep 27, 2008 | 07:40 PM
dudegetalife
how do you remove the fuse what tool do you use?
Old Sep 27, 2008 | 07:46 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You can use a tool that usually comes with the packaging that fuses are in, tweezers, or needlenose pliers.
Old Sep 29, 2008 | 12:58 PM
M3ANMACHINE
Isn't there a fuse removal tool inside the fuse box??? Thats what I used... If you would have just checked you would have saved lots a time. It's much easier than you're making it
Old Oct 3, 2008 | 01:41 PM
dhays's Avatar
dhays
The thread is a bit old but...
I went through about 3 of the 15 amp cig lighter fuses last weekend. If I plugged or unplugged my cell phone charger into the lighter when it was powered up, the fuse would blow. Not sure if this is a problem with my charger adapter, or the lighter socket. Anyone have any ideas?
For now, I'm just trying to remember to not do it, and I've got a box of spare 15amp fuses in the car now as well.
Old Oct 3, 2008 | 06:04 PM
M3ANMACHINE
Probably your charger. But I would just not use it in the car if it kept doing that... Can you check to see if anything else that plugs into the outlet blows the fuse also?
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
