65000 mile
Old Sep 30, 2008 | 06:06 PM
quietkilla6's Avatar
quietkilla6
Default 65000 mile
just got 65000 miles. does anyone know where i can find out what needs to be done as far as tune up or fluid swaps anything like that? (please dont say stealership i hate that place.)
i figure coolant
transmission
real gear fluid
oil (obvious)
sparkplugs?
belts changed when i bought it.
i asume theres already a thread but i can never find it untill i dont need them.
Old Sep 30, 2008 | 06:09 PM
dmroberson's Avatar
dmroberson
I typically follow the Schedule 1 maintenance schedule on Nissan's website...
http://www.nissanusa.com/owning/vehi...intenance.html
Just select your mileage... I usually do as much of the maintenance myself. If I can't do it all, I take it to a shop to do the rest.
Old Sep 30, 2008 | 06:12 PM
lottness's Avatar
lottness
seems like this should be covered in your owners manual, thats if you still have it. Not sure about the z since i only got 23000 miles on my 06 so far but i know my GTP owners manual went over service requirements up to 200k miles. Other than that dont really know what to tell you except maybe search around some more on the forums possibly.
Old Sep 30, 2008 | 06:20 PM
quietkilla6
Originally Posted by 06-Z
look at the owners manual. it says what needs to be done when u hit a certain amount of miles.
yea i should have mentioned that i didnt get a owners manual when i bought the car used at 45000 miles.
Old Sep 30, 2008 | 06:29 PM
DavesZ#3's Avatar
DavesZ#3
It doesn't matter, it's not in the Owners Manual anyway, it's in the Maintenance Manual. Assuming that you didn't get it either, you can download one from the Owners section of the Nissan website or from their Tech info site: http://www.nissan-techinfo.com/nissan/
Old Sep 30, 2008 | 06:51 PM
quietkilla6
thanks 06-Z thats awsome of ya bro. thanks everyone else for the help also
Old Sep 30, 2008 | 07:16 PM
quietkilla6
hey bud, since u said u never got ur manuals, i took at look at mine and the things u have to do at a 60,000 mile maintenence check is as follows:
replace engine oil and filter, lubricate all locks/hinges, replace automatic transmission/CVT fluid, replace differential oil, replace engine air filter, replace engine coolant/flush system, replace engine drive belts, replace in cabin microfilter, replace manual tranmission oil, replace radiator cap, replace radiator hoses, replace transfer oil
and it says to inspect
all lights, axle and suspension, break lines and cables, brake pads, rotors, drums and linnings, cruise control vacuum hoses, drive shaft boots, exhaust system, front suspension ball joints, fuel lines/connections, fuel tank vapor vent system hoses, propeller shaft, steering gear and linkage and steering linkage ball joints
thats all the stuff u gotta do, but prob dont have to do half of the ones listed by the manual
did the 06 come with cvt? or is it just being general?
Old Sep 30, 2008 | 07:45 PM
quietkilla6
im pretty sure it does because i also have a 2006 350z, meaning i have an 06 manual and it does not say (except 350z) for the cvt checkup because on some check up's that were on the list it says specifically (EXCEPT 350Z)...u should get nissan to check if u actually need to replace the fluid cuz they have a machine they use to check, because i know that fluid is pretty costly
Yea its pricey stuff. I have crayon markings on my transmision plug and some mechanic said thats means its been changed. For only 65000 miles it doesnt seem you should change it more than once. I wish they would have made some way to view the fluid without a machine. i can do everything on that list myself really. dont think it should cost much in parts (fluids).
Old Sep 30, 2008 | 07:59 PM
quietkilla6
well sounds good. u should just go check if u need the fluid changed just to be on the safe side. or ask another mechanic to verify if the crayon marking actually means that the fluid has been changed.
word. thanks for all the help man
Old Oct 2, 2008 | 02:00 PM
chromesilverz's Avatar
chromesilverz
All of thoses except the sparkplugs if they haven't been changed yet.
Spark plugs are good till 100k.
Old Oct 4, 2008 | 11:06 PM
SoldzMyZ's Avatar
SoldzMyZ
I did my 60k recently. Did a coolant flush (total ***** to do btw), differential and transmission fluid. Oil change and filter (amsoil once/year). air filter wash/recharge. Checked brake pads/tires. Did it my self so spent about 150 in all.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
