NEED HELP WITH SERVICE ENGINE SOON LIGHT
Old Oct 5, 2008 | 06:27 PM
ramkat's Avatar
ramkat
Default NEED HELP WITH SERVICE ENGINE SOON LIGHT
I cant seem to get rid of this light, it turned on after 3000 miles. so i change my oil and filter. and thought resetting it would be easy..i did the manual reset way. acc on for 3 sec.. step on gas 5 times within 5 secs, ..wait 7 secs..then step on gas and hold for 10sec release and wait 10 secs, press on gas hold again for 10 secs then release...turn off acc then start the car...
i dont know maybe my timing is wrong or sumthin....i have an 08 z...pls help anyone help...
Old Oct 6, 2008 | 02:58 AM
DavesZ#3's Avatar
DavesZ#3
The manual reset is NOT easy. Timing is too critical.
Go to an Autozone and they will read the code for you. They can also reset it.
You can also disconnect the battery then step on the brake to drain the power from the ECU. That shouldl clear the light but you'll never know what the problem is.
Old Oct 6, 2008 | 10:35 AM
ramkat's Avatar
ramkat
ok thanks does autozone charge to read the code?
ill try the disconnect the battery way today...hopefully this works
Old Oct 6, 2008 | 11:23 AM
WTX350Z's Avatar
WTX350Z
Nope
don't do that. the code might go away...want to know what's wrong before you go deleting stuff.
Old Oct 6, 2008 | 04:31 PM
ramkat's Avatar
ramkat
Originally Posted by WTX350Z
Nope
yah im at work right now, i realized that too, so i will just go to autozone when i get a chance thanks.
Old Oct 11, 2008 | 12:56 AM
350ZTheStandard's Avatar
350ZTheStandard
Great info I get the service engine light also from time to time, guess I am off the AZ this sunday.
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
