I need a bit of direction, help appreciated.
Old Oct 23, 2008 | 11:45 AM
superjhon7711's Avatar
superjhon7711
Default I need a bit of direction, help appreciated.
Well ive been driving my New semi used 2003 Z (12000 miles) for about 4 Months now. Everything was running flawlessly until today, i came out of work started the car and MY VCD, SLP AND Engine Check light came on.... i would step on the gas and the car wouldn't even get to 1K RPM.
Being puzzled by it, i turned it off and on a few times and finally the car came back to normal, this time the Engine Check Stayed on.
Has anybody experience this, or has come a cross a thread that has similar symptoms?
Any help would be appreciated.
Old Oct 23, 2008 | 11:48 AM
Entaille's Avatar
Entaille
not that this helps much and others will give you much better info, but it sounds like the car went into limp mode - so you can still roll it slowly if you need to. without the CEL codes I don't imagine we can take a wild stab at what is actually wrong.. but again wait for more expierienced mechanics to post their thoughts : )
Old Oct 23, 2008 | 11:57 AM
samjcg's Avatar
samjcg
+1 on limp mode.
There are many threads about this in this forum.. search for it and you will find where you need to take your car.. I can't think any on top of my head.. sorry
Old Oct 23, 2008 | 12:08 PM
WTX350Z's Avatar
WTX350Z
Get codes pulled. can buy a code puller for like 20 bucks@ harbor freight sometimes...or goto autozone, they'll scan it for free.
Old Oct 23, 2008 | 12:09 PM
superjhon7711
Default THANK YOU VERY MUCH
Limp mode, cool. I'll make some research on it and try to crack this cookie.
Old Oct 23, 2008 | 12:59 PM
Entaille's Avatar
Entaille
the limp mode is just engaged to protect the car. somethings wrong - you can limp it on over to autozone and they will scan it for free as mentioned from WTX - they probably can't diagnose that code for you but they are easy to google/search this forum for..
Old Oct 24, 2008 | 12:35 PM
Sol@rZ's Avatar
Sol@rZ
Default Help Appreciated
I also need bit of direction regarding a problem that I’m having I think it’s either a sensor or a switch. My car was working fine with no indication of any trouble until I tired to start with no luck. The headlights, radio and wipers all still are operational. So I tried to start it in Neutral (thinking it was the inhibitor switch)--no luck. I even checked all the fluid levels. The only way I could get the car to run was by connecting the starter to the solenoid. When I tried to put it in ‘drive’ it was very sluggish, but it drives perfect in reverse. I’m thinking it’s a transmission switch or something but I figured that someone who had the same problem might offer a suggestion. (besides driving in reverse).
Any suggestions would be appreciated.
Old Oct 24, 2008 | 04:48 PM
Dr. Venture's Avatar
Dr. Venture
another reason to by a MT!!!!
that sensor problem which is probably what one of the codes is....is a crank angle sensor, or a cam pos sensor problem. One of those will hinder you car from starting.
Cam Sensors L pt# 23731-AL61A
R pt# 23731-6J90B
Crank Sensor pt# 23731-AL60C
Dsowe
Feb 17, 2021 10:38 AM
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
