Post here only if you have had your TRANNY replaced.
Old Oct 27, 2005 | 11:10 PM
  #661
DAYTONA-ZED's Avatar
DAYTONA-ZED
Originally Posted by BriGuyMax
Why does it indicate that the engine is programmed to idle too low?? It idles around 650rpm just like many many other vehicles out there.
Ive owned mustangs and camaros that idle smoother than this Z. Its not even an idle its more like a stumble. I asked the dealer service dept if they could bump up the idle and they said that was not possible. WTF?
Old Oct 27, 2005 | 11:31 PM
  #662
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by DAYTONA-ZED
Nah. 2005 GTO . Looks like a rental car, but goes like hell.
And you think you have issues with you Z.....just wait.
Old Nov 3, 2005 | 09:31 AM
  #663
robbycolli's Avatar
robbycolli
Default My problem exactly.
Originally Posted by albatross83
Is there a TSB on this problem? I've got grinding in 5th gear, and the dealer is trying to tell me it's from the way I'm driving it. On the test drive I shifted 2nd to 5th at ~50MPH because that's the easiest way to demonstrate the problem -- the higher the RPMs are above the perfect rev match, the more it grinds. Which indicates, to me, a synchronizer problem. It does it in a shift from any gear to 5th, as long as the difference in RPMs is significant enough. (e.g., if you're shifting at 2500RPMs the whole time, obviously the drop isn't going to be enough, and it you take more than 1/2 sec to shift, the RPMs have already fallen enough that it won't grind). If there's no TSB, I'm tempted to print out all 31 pages of this whole post and bring it in to the service department.
I could not have described my problem any more clearly. What has been your outcome? Thanks. Rob Collins
Old Nov 9, 2005 | 12:27 PM
  #664
robbycolli's Avatar
robbycolli
Just got confirmation that Wilmington Nissan is putting a second transmission in my second Z. That's 4 in all. Rob
Old Nov 9, 2005 | 12:28 PM
  #665
robbycolli's Avatar
robbycolli
Only one replacement in each car. Rob
Old Nov 10, 2005 | 12:53 PM
  #666
JCat's Avatar
JCat
Had my tranny replaced at 12,000 miles due to it locking-up in 5th gear.
I'm at 22,000 miles now, and while crusing at highway speeds with the clutch fully pressed, when I shift back and forth from 5 to 6 and back to 5......I get a definate GRIND.
Looks like I'll be getting a THIRD tranny.
I have actually been babying this second transmission.
Old Nov 10, 2005 | 01:02 PM
  #667
TXSTYLE's Avatar
TXSTYLE
Yeah....... It is truly sad that can not get solved. I have absolutely nothing but great things to say about my 2003 Performance model except the tranny and negative camber. But I still say that for the $... Nothing can touch it in (listen carefully): Style & Performnace.
Old Nov 10, 2005 | 03:23 PM
  #668
Netko350Z's Avatar
Netko350Z
^ eeekk TXSTYLE that was post#666!!!
Old Nov 11, 2005 | 06:30 AM
  #669
gimpster621's Avatar
gimpster621
anyone with 05's have tranny issues? heres my problem... https://my350z.com/forum/maintenance-and-repair/153199-tranny-woes.html
any input will be appreciated
Old Nov 13, 2005 | 11:30 PM
  #670
Acree's Avatar
Acree
Originally Posted by gimpster621
anyone with 05's have tranny issues? heres my problem... https://my350z.com/forum/showthread.php?t=153199
i have a 2005 and i am currently on my 3rd tranny. 5k miles so far and still smooth as butter.
Old Nov 14, 2005 | 04:54 AM
  #671
JCat's Avatar
JCat
Question:
If I'm averaging a NEW TRANNY every 11,000 miles.............what will Nissan do for me once the warranty expires ?
Old Nov 14, 2005 | 05:53 AM
  #672
zillinois's Avatar
zillinois
Transmission replaced 04/05/05 for 3rd gear grinding at 7000 miles. Dealer warrantied at JP Chevrolet/Nissan.
Old Nov 14, 2005 | 06:38 AM
  #673
clipso 01's Avatar
clipso 01
how much does a tranny replacment cost without a warranty? i just bought an 03 w/48,000 miles, and have grinding in 3rd and 5th. dealer said i have up to 60 on the origonal drivetrain warranty.
Old Nov 14, 2005 | 07:59 AM
  #674
DAYTONA-ZED
Check nissan parts sites on the tranny price then get a per hour installation quote and how many hours to install.
Old Nov 14, 2005 | 08:08 AM
  #675
TXSTYLE's Avatar
TXSTYLE
Arrow
Dude..... You must not have said what you meant?
01 how much does a tranny replacment cost without a warranty? i just bought an 03 w/48,000 miles, and have grinding in 3rd and 5th. dealer said i have up to 60 on the origonal drivetrain warranty.
That is correct. The "powertrain warranty" is good for 60k miles. According to my last warranty repair, the charges listed totaled @ $2,500 if I am correct. Somehow I bet the charges would be a little higher if one were out of warranty...
Well I won't be finding out. It appears they are good (at least in my case/driving) for @... Well come to think of it... all 3 were sorta longer than the previous:
1st = 5k miles
2nd = 15k miles - And it went all the way up to @ 42k miles!
3rd = I plan to replace my Z this Spring/Summer and I drive @ 1k - 1,200 miles a month. That should be anywhere from 6k - 8k miles more for me. If all goes according to plan...
Old Nov 16, 2005 | 03:32 PM
  #676
Dissident's Avatar
Dissident
Well, I just scheduled my appointment for my first tranny replacement. 34K miles here but it's been grinding for a little bit now.
Now, to pick a different flywheel...
(p.s. just got my second set of new front tired under warranty on my 04)
Old Nov 22, 2005 | 08:01 PM
  #677
leuhuckun's Avatar
leuhuckun
Dear fellow 350Z owners,
I was wondering if you could help me. My Z has 11,000 miles and a few problems may exist. When my clutch is not depressed it makes a rattling sound but when depressed it stops. Also, when shifting into 2nd, clutch fully depresssed it makes a clunk/grind sound, sometimes shifting into 3rd and 4th it isn't so smooth.
Acme South Brunswick Nissan gave some push back on the issues saying they will monitor it but have not ruled out replacing.
Again, I would greatly appreciate it if you could help me. ie: what to say, how your tranny was acting etc
Thanks!
Old Nov 23, 2005 | 03:36 AM
  #678
g_torphins's Avatar
g_torphins
Gearbox replaced at 24K miles(Eventually )
NissanGB wanted to repair but luckily for me parts were
taking forever to arrive so finally got new 'box.
Grinding started when shifting 3rd to 5th.
Hopefully will be the only replacement needed....
George
Old Dec 2, 2005 | 01:08 PM
  #679
Chicago Black Z's Avatar
Chicago Black Z
Transmission replaced at 9k miles, grinding in 6th gear. Nissan replaced it under warranty. Apparently I also had a worn flywheel and clutch cover which I had to pay for myself. Weak.
Old Dec 2, 2005 | 01:14 PM
  #680
LIdrew's Avatar
LIdrew
When I had mine replaced @ 17k miles, they replaced the clutch and flywheel at no charge. I would fight them on that. How is clutch gone @ 9k miles?? You would have to be totally beating on it beyond belief or have never driven manual before. Even then, I think it would last over 9k miles.
