fuel door stuck
Old Dec 8, 2008 | 09:39 AM
Slickdvl's Avatar
Slickdvl
Default fuel door stuck
So I got about 51dt left on the car, go to fill up today. Hit the button, and the damn door won't open. What the? Anyone know how to fix it? It's cold outside, but it's not that cold (I think it was like 30c).
Old Dec 8, 2008 | 09:45 AM
KManZ's Avatar
KManZ
You take the keys out of the ignition?
Old Dec 8, 2008 | 10:00 AM
I‘ve had it happen twice in 5 years. Opened the door with a plastic credit card. Spray the linkage with WD40.
Old Dec 8, 2008 | 10:02 AM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
What does that have to do with anything ? Are you suggesting to use the key to pry it open ?
I would put pressure on the gas door by the latch and have some one hit the release button several times really fast. Make sure you aren't pushing on the door when they hit the button.
Old Dec 8, 2008 | 10:09 AM
Slickdvl's Avatar
Slickdvl
Tried that, i hit the button while they bumped the door.
Old Dec 8, 2008 | 10:10 AM
Slickdvl's Avatar
Slickdvl
Should the car be on? I tried everything, car off, car on, just the 2nd turn with key on (turn electrical on).
Old Dec 8, 2008 | 11:07 AM
KManZ's Avatar
KManZ
There was this one time when I hit the fuel door button when the key was in the ignition, and it didn't open maybe it was coincidence.
I don't know, seems more reasonable than holding the fuel door down while someone else presses the button, but making sure not to hold the fuel door down when they press the button...
Old Dec 8, 2008 | 11:12 AM
Slickdvl's Avatar
Slickdvl
I hit the button initially, then I tried holding it. Nothing worked. I got a feeling the dealership screwed something up last time I brought it in (haven't filled up since). I brought it in for oil mark off + excessive fuel consumption.
Old Dec 8, 2008 | 06:22 PM
Slickdvl's Avatar
Slickdvl
Looks like I am going to the dealer to get this fixed.
Old Dec 8, 2008 | 06:25 PM
350Ricky's Avatar
350Ricky
I like Rice
Did you check the fuse?
Old Dec 8, 2008 | 06:27 PM
Slickdvl's Avatar
Slickdvl
where is it?
Old Dec 9, 2008 | 05:37 AM
Slickdvl's Avatar
Slickdvl
anyone know where the fuse is located and the name?
Old Dec 10, 2008 | 12:28 AM
350ZTheStandard's Avatar
350ZTheStandard
FUSE???? I believe it has a cable & mechanical release.
Old Dec 10, 2008 | 05:44 AM
Slickdvl's Avatar
Slickdvl
took it to the dealer. Apparently there was a problem between my stock alarm and the compustar I had installed way back. I think the last time I took it to the dealer they somehow re-armed the stock one (haven't filled up since) causing it to lock the fuel door. Compustar unlocked and started the doors just fine though, so I don't get it.
Old Jan 9, 2012 | 08:25 AM
JRVBCoach's Avatar
JRVBCoach
Default Door Latch Alignment Issue
My fuel door latch would barely release when pressing the release button. I found the cause was poor alignment between the latch and the door release - it was slightly to one side and although the release button was working the doorr would get caught. MY FIX - open the fuel door and check the alignment using a flash light. If you can see the side that is getting caught you can loosen the two phillips screws holding the door hinge on move the door slightly to release this binding at the latch mechanism. Worked for me perfectly and now the door releases about an inch the first time I hit the release button. I no longer have to use a credit card to gently pry open the door.
Hope this helps some others with the fuel door latch issue.
