cluster lights
Old Dec 24, 2008 | 08:45 PM
thomas'Z's Avatar
thomas'Z
Default cluster lights
ok i got my z back from beind repaired 2 days ago because i broke the slave cylinder n the clutch pivot bolt
now my Service engine light - TCS light - and Slip light are all on
i push my TCS button to make it turn off but it wont, and i have no clue what the Slip light means.
any ideas what coulda went wrong.
and note its an 04 base i bought it from huntington beach ford (which i recommend never going to) with no warrenty.
Old Dec 24, 2008 | 08:47 PM
mclovin.too's Avatar
mclovin.too
I was not aware base models had TCS?
Old Dec 24, 2008 | 08:50 PM
thomas'Z's Avatar
thomas'Z
it does, or it might be enthus but pretty sure its base
Old Dec 25, 2008 | 12:26 AM
350ZTheStandard's Avatar
350ZTheStandard
Maybe search would be a good idea, base models don't have TCS, slip is also found by searching. Welcome
Old Dec 25, 2008 | 05:08 AM
DavesZ#3's Avatar
DavesZ#3
It doesn't matter which model he has and whether or not he has TCS/VDC - his problem is that something is broke. Unfortunately, none of the symptoms would normally be related to the repairs.
The shop may have damaged or disconnected something by accident.
The first things I WOULd check are to make sure you have enough brake fluid. Low fluid can trigger the Brake/VDC/TCS/Slip lights.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
