P0340 Bank 1 Code thrown.....CMP Circuit Malfunction
Old Dec 30, 2008 | 03:29 PM
3_FILTHY_Z's Avatar
3_FILTHY_Z
Default P0340 Bank 1 Code thrown.....CMP Circuit Malfunction
Ok...I have searched all over the web, all over this forum and have found some really good info about this code. I do have a friend with a TT G35 that had this code along with the other bank and the CSP Sensor. Ok, my options as I know them is to either:
* Visually inspect all the wiring and connectors in the circuit
* Check for continuity in the circuit wiring
* Check the operation (voltage) of the camshaft position sensor
* Replace the camshaft position sensor as required
* Check the crankshaft position circuit as well
* Replace circuit wiring and/or connectors as required
* Diagnose/replace the PCM as required
So, I was wondering what everyone has experienced in replacing when this code was pulled on their car. I've heard anywhere from having to just replacing the 1 sensor that was thrown and everything was fine to having to replace all these 3 sensors and the PCM....so I just want to see what to majority has been and get an idea how much I'm going to spend for this repair at the moment. Thanks in advance...
edit....it is the P0340 code, not the P0304 code....my mistake
-Brian
Last edited by ACEMAN; Dec 31, 2008 at 03:58 PM. Reason: User wanted it changed to P0340
Old Dec 30, 2008 | 03:35 PM
JETPILOT's Avatar
JETPILOT
It might not be a sensor at all. 0304 is a #4 cylinder misfire. It could be anything. I had a 0306 code the other day and it turned out to be that an injector had failed open and was pouring fuel into the cylinder causing a misfire.
Old Dec 30, 2008 | 04:41 PM
3_FILTHY_Z's Avatar
3_FILTHY_Z
Mods could you please do me a favor and change the code in the thread title if possible....thanks.
Old Dec 30, 2008 | 07:18 PM
JETPILOT's Avatar
JETPILOT
0300 is a common and normal code for turbo cars. Get used to it. It's there to stay.
Old Dec 30, 2008 | 07:25 PM
3_FILTHY_Z's Avatar
3_FILTHY_Z
mines N/A
Old Dec 31, 2008 | 11:06 AM
solosoljur's Avatar
solosoljur
Default been there
you can try n replace that sensor but there is no gaurentee that it will fix. i replaced all and still the car doesn't start.
Old Dec 31, 2008 | 05:54 PM
3_FILTHY_Z's Avatar
3_FILTHY_Z
How's it going Joey.....I'm thinking that if I've only thrown the P0340 and it's thrown it 3 times and no others, I may get lucky. Since you had multiple, I'm afraid that yours might be your PCM.
Old Jan 2, 2009 | 10:02 PM
3_FILTHY_Z's Avatar
3_FILTHY_Z
Thanks mods for correcting my thread topic. It's going to Nissan tomorrow morning and we'll see if it's just the bank 1 sensor. I have extended warranty and it should be covered. I also found that my passenger side rack boot is leaking and the top plug on the pump is leaking. Nice.
Old Jan 22, 2009 | 07:07 PM
NISMOFO's Avatar
NISMOFO
I just got this code yesterday (P0340). I guess I should start checking the wiring before spending any money on sensors? How much are these sensors anyways?
Lastly, what is the PCM?
Old Jan 22, 2009 | 07:16 PM
NISMOFO's Avatar
NISMOFO
Just sent you a PM. Curious what Nissan did with the car? I'm in McKinney as well.
Old May 25, 2009 | 11:13 PM
BlackSpec02's Avatar
BlackSpec02
I just got this code. Any insights on what to do? Is the car safe to drive for a day or so until I can take it in?
Old May 26, 2009 | 11:57 AM
BlackSpec02
Scheduled to drop the car off at mossy nissan 1st thing AM.
Old May 27, 2009 | 08:46 PM
BlackSpec02
So I dropped my Z off at the nissan dealer this morning. They called and said it was done at lunch but when I showed up to pick it up, it threw the same code again and didnt want to start. They realized they changed my crank sensor and not the cam sensor... so they fixed it and I was able to return after work today to pick it up. When I got it after work it seemed like all was well... and I havent had any problems yet. (knocks on wood). I drove it about 30 miles since picking it up this evening. Cost $320. Time: 1 full day at the dealer.
lolwatbro
Oct 9, 2021 04:58 AM
350Z Project X
Oct 17, 2015 05:16 PM
Mattg350z
Oct 2, 2015 06:51 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
