omg help :) 2
Old Jan 2, 2009 | 10:42 AM
MyIS300's Avatar
MyIS300
Default omg help :) 2
I started noticing condensation to both my right/left front head lights? what's the fix? how can I replace my lights, they see very dim compared to my old is300 and other z's. i have a 2005zr touring yellow
Old Jan 2, 2009 | 07:36 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Jan 7, 2009 | 05:03 PM
10-E-C-350Z's Avatar
10-E-C-350Z
Crap, if it was blue I would be able to help. Good luck.
Old Jan 7, 2009 | 05:08 PM
k6750gsxr's Avatar
k6750gsxr
Remove light and re seal them.
Old Jan 7, 2009 | 05:22 PM
AshMan's Avatar
AshMan
Club Moderator
the Hot Spot
that's just what I needed.
Old Jan 8, 2009 | 06:25 AM
krypto's Avatar
krypto
Squeaking brakes
instead of
Help
or how about you give him advice and if not, move on? you average almost 20 posts a day, hopefully you dont just bs to up your post count
Old Jan 10, 2009 | 09:43 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Are you sure it's on the inside of the lense? As 350's do tend to have issues with the exterior of the headlight lense hazzing over. If that's the case, do a search, there's plenty of threads about it.
Old Jan 24, 2009 | 05:54 PM
MyIS300's Avatar
MyIS300
it's def inside condensation, today my lights inside didn't turn on any more.. my high beams were able to turn on... I think the bulbs are burned..
Any suggestions?
Old Jan 24, 2009 | 05:58 PM
LastODJedi's Avatar
LastODJedi
§ith Mã§t€®
Ummmm... Get new bulbs????????
Old Jan 24, 2009 | 08:46 PM
ladyzed's Avatar
ladyzed
Squeaking brakes
instead of
Help
Yet another helpful post from David Vishkoff
Old Jan 25, 2009 | 09:02 AM
KeithGT's Avatar
KeithGT
Any suggestions?
I just had this issue myself. More than likely your bulbs arent burned out, but your HID ballist, which is attached to the bottom of your headlight, has water in it. Your ganna have to take your headlights off your car, take off the ballast and let them dry out. Since i have no sun or warm weather, i used a work lamp that gets hot and it worked great. Why you have you headlights out, do the oven trick, take them apart and re-seal them. Dry them out first, which was hopefully obvious.
Hope this helps!
Old Jan 25, 2009 | 09:09 AM
bbs350z's Avatar
bbs350z
take apart your headlights, dry them, and reseal. no biggie
zand02max
Videos
Oct 20, 2004 03:03 AM
missy1101
Jun 11, 2003 06:06 PM
phattyaltnatl
Aug 18, 2002 11:42 PM
