08 base with 5500mi and already a rough idle
Old Jan 14, 2009 | 11:32 AM
volcomfaraz's Avatar
volcomfaraz
Default 08 base with 5500mi and already a rough idle
so i purchased my car july 08 and it only has 5500 miles on it. recently ive been having rough idle issues(turn car on on a warm start, car turns on, rpm goes up but on its way back down it drops to about 400 and then comes back up to about 550-600)
shall i just take it to the dealer and have them diagnose/fix problem under warranty?? the car only has 5500 miles on it!!
thanks
Old Jan 14, 2009 | 11:34 AM
SS21CA's Avatar
SS21CA
I'm assuming you don't have any mods like an intake etc...
I would say take it to a dealer. Whatever it is, it should be under warranty.
Old Jan 14, 2009 | 12:37 PM
volcomfaraz
no mods, bone stock.
Old Jan 14, 2009 | 12:42 PM
BigMo350z's Avatar
BigMo350z
Go straight to your dealer! Get your money's worth! 08 here is 1700 miles going strong! If I have any problems dealership comes first.
Old Jan 14, 2009 | 01:51 PM
zete350's Avatar
zete350
Take it to the dealer.
Old Jan 14, 2009 | 02:10 PM
mclovin.too's Avatar
mclovin.too
Dealer then report back.
Good luck.
Old Jan 14, 2009 | 04:00 PM
quietkilla6's Avatar
quietkilla6
probley just a censore in your intake unscrew it from the tube and clean it... well if the stealership wants to charge you that is.
Old Jan 15, 2009 | 07:23 AM
HondaKiller's Avatar
HondaKiller
Zs suffer from rough idle's, there not going to be able to fix, dont worry though, it will grow on you after awhile lol
Old Jan 15, 2009 | 08:40 AM
j.arnaldo's Avatar
j.arnaldo
Stealership time! BTW, my 'O4 Touring Coupe purrs like a kitten; no rough idle at all, at 19,190k. That can't be "normal". Also, try changing gas stations; it could be moisture in the fuel, etc. I only get Texaco, 'cause of Techron.
Old Jan 15, 2009 | 10:58 AM
Tac-M's Avatar
Tac-M
all that is normal, if i come up to a stop light after a fast run/brake mine does it too. my 05 did the same thing. once again that is normal.
Old Jan 15, 2009 | 05:00 PM
mikedbz's Avatar
mikedbz
My 04.5 does not do it.. maybe not normal in some percentage of cars?
Old Jan 16, 2009 | 04:06 AM
35Z's Avatar
35Z
Default Rough Idle on 98 350Z
I'm in for the dealership reason(s) for the rough idle.
I guess you have already changed the oil for the first time and had the air filter check/changed.
Could be a number of items; MAF sensor fouled, O2 sensors fouled, intake fouled, spark plugs fouled,etc.
liqalu04
Jan 2, 2022 12:58 PM
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
