hesitating/loss of power
Old Feb 25, 2009 | 08:47 AM
HondaKiller's Avatar
HondaKiller
plugs are probably causing the power loss off the go. Be ready to replace your vavle gasket at the same time because your plugs will probably have oil on them.
Old Feb 25, 2009 | 01:48 PM
SuperBlack350z's Avatar
SuperBlack350z
if he has oil on his plugs, he will need to change his valve cover, not the gasket. Only change the gasket if there is oil leaking out of the valve cover itself.
Old Feb 25, 2009 | 01:54 PM
ohfourzee's Avatar
ohfourzee
I have the smale exact problem and am taking it to the dealer tomorrow. I read an old thread it was the air flow meter causing the problem, covered under normal warranty for cars under 36k miles.
Old Feb 25, 2009 | 01:58 PM
cracka350z's Avatar
cracka350z
my car has 120k miles lol. no warranty for me. its confirmed though...it only happens after its been warmed up and driven a bit. so i drive from home to the gas station near work, turn it off, then come back out and crank it up...it seems like it struggles to start, almost like a fire issue so the plugs are comin out tonight. (the starter ect is fine...just fyi)
Old Mar 4, 2009 | 03:18 PM
ADMAN's Avatar
ADMAN
Any updates???
Old Mar 11, 2009 | 11:06 AM
Toby-22's Avatar
Toby-22
I think my issue is coming from bad Spark plugs and Knock sensor. I will replace both this weekend and see what happens.
Old Mar 15, 2009 | 02:04 PM
Toby-22's Avatar
Toby-22
Just changed the spark plugs and that seems to have helped. My throttle response is a lot better but i do still have that lag under 3k rpm. Not as bad as before but it's still there?? It seems a lot of people are getting this issue but no one knows the fix? I will look into my knock sensor this week
Old Mar 16, 2009 | 08:29 PM
BallZdeepNYC's Avatar
BallZdeepNYC
why would leds make a difference in power?
Old Mar 17, 2009 | 11:23 AM
Coldcat83's Avatar
Coldcat83
+1
Old May 1, 2009 | 11:58 PM
GiftOfGab's Avatar
GiftOfGab
Sadly I'm having the same problem just recently my car starts to lose power around 3k...
I punch it in 6th on the highway and the car doesn't go anywhere...CEL turns on for a quick second then turns off
mechanic thinks it may be the knock censor or MAF censor....very frustrating
Old Nov 3, 2009 | 03:30 PM
NISMOFO's Avatar
NISMOFO
It sounds like my car does the exact same thing recently. Did you ever resolve this issue?
Old Nov 8, 2009 | 09:27 PM
POWUH's Avatar
POWUH
same , my car seems much faster when its cold then warm , and before I would beat mustangs gt , now they beat me :/
Old Dec 2, 2009 | 09:15 PM
Eurostyle's Avatar
Eurostyle
mmm i got a major lag problem... whehn i give gas my rpms shoot up then back down to regular its almost like something is stopping it from accelarating normally but has to shoot up then back down, lags then accelarates... soo frustrating to drive...
Old Dec 3, 2009 | 08:37 AM
cheshirecat79's Avatar
cheshirecat79
see the other thread you posted.
Old Dec 3, 2009 | 11:13 PM
dirtbikr's Avatar
dirtbikr
haha, i almost died laughing. Wonder what that could be?!?!
Old Dec 22, 2009 | 12:36 PM
Dui-Dan's Avatar
Dui-Dan
^^ I know this is a little late, they probably already paid 2500 for the dealership to fix it. Clutch and flywheel fried buddy...
I had the same issue. Spark plugs helped. Took off intake and exhaust, cleaned all the gunk out, breathing better now. Test pipes had a fair amount of carbon in it (running rich?). Cleaning the fuel system now.
Old Dec 22, 2009 | 12:48 PM
abo's Avatar
abo
it sounds like i have the same problem but i drive an auto. so i'm wondering if it might be diffrent problem. but the weather cleared up, new air filter, engine oil, gear oil, tire rotation(jk jk on the tire rotation) havn't been able to replicate the problem. i thought my problem might have been a combination of low tire pressure and sucking up a little water in the CAI. but i'm not a master tech so i don't really know myself.
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
