running lights not working
Old Feb 25, 2009 | 08:09 PM
sbickle350z's Avatar
sbickle350z
Default running lights not working
got pulled over tonight and police said my running lights are not on but brake lights work. Thoughts? Headlights work but that is it.
Old Feb 25, 2009 | 08:17 PM
maximariceboi's Avatar
maximariceboi
change the bulbs?
Old Feb 25, 2009 | 08:21 PM
sbickle350z
everyone of them?? seems kinda odd that all of them r out. I just installed a new headunit. Is there a wire that i did not hook up?
Old Feb 25, 2009 | 09:11 PM
maximariceboi
check your fuses/relays....
i dont think the headunit has anything to do with it....i might be wrong since i never took one out of a Z.
sorry im not much of a help here...
Old Feb 26, 2009 | 07:02 AM
sbickle350z
were is the fuse box located for those lights
Old Feb 26, 2009 | 08:21 AM
EE Z's Avatar
EE Z
Could be the fuses, since you're headlights have thier own fuse. pm me ur email and I'll shoot you a pic of where the fuse box is
Old Feb 26, 2009 | 09:15 AM
maximariceboi
you can also download a factory service manual online.....its free!
Old Feb 26, 2009 | 10:50 AM
sbickle350z
all the fuses e good. If i did not hook up the illumination wire in the back of my new headunit will that make a difference
Old Feb 26, 2009 | 10:58 AM
sbickle350z
just took make it clear i am talking about my rear lights not daytime running lights. When i turn the headlights to the middle setting nothing happens and then i turn it all the way and the headlights come on. the hazards work and turnsignals but not the night running lights.
Old Feb 26, 2009 | 07:58 PM
sbickle350z
thanks for everyones help. found the 10 amp tail light fuse under the hood that was out
Old Feb 26, 2009 | 08:25 PM
maximariceboi
glad you found the problem.
Old Apr 16, 2014 | 05:56 AM
c5downlow's Avatar
c5downlow
Hey guys.. im havimg similar issue with my Z... i checked all the fuses... they r fine... but when i take off the batt connection and put it back on it starts to work for some time. Any ideas?
Old Nov 28, 2023 | 08:46 PM
issamo06's Avatar
issamo06
Unhappy Break Lights work but tail lights don't work..
Ok so I had these headlights on my car. They were Autozensation Halogen jdm projector headlights. They have LED lights that would turn on with my tail lights (I'm guessing its called running lights) but recently they haven't been turning on. So I checked my front lights and one the wires was rubbing against my tire and rip the cables open that connect to the LED Lights. I'm guessing they open wires touch and maybe shorted a fuse or something which is why both front and rear LED Lights are not working. But I check all the fuses and I'm not finding one thats blown. I'm really hoping the rear lights didn't burn out because of what happened (I don't know if that's possible let me know if it is or not) but yeah I can't seem to find the issue.
Old Jul 9, 2024 | 07:08 PM
elijblac's Avatar
elijblac
Default I had the same exact thing happen
Did you ever find a solution? My tire rubbed through my harness as well and I repaired all of the freyed/broken wires but my running lights and my headlight bulbs are still not working. I checked all the fuses and the headlight bulbs they’re all fine.(one headlight bulb works but cuts on and off) Still not sure why none of this would be working. Brake lights work but not the running tail lights.
Miguel Albanez
Oct 17, 2022 10:13 AM
350z_z33.
Jul 3, 2017 04:01 AM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
Shane86
Sep 17, 2015 05:33 PM
