Where is the water pump?
Old Mar 14, 2009 | 04:55 PM
ChopstiX's Avatar
ChopstiX
Default Where is the water pump?
Does anyone know where the water pump is located on a 2003?
Old Mar 14, 2009 | 05:07 PM
DavesZ#3's Avatar
DavesZ#3
See diagram...
Old Mar 14, 2009 | 05:11 PM
SoldzMyZ's Avatar
SoldzMyZ
It looks like our water pump is kinda easy to get to compared to other cars just
Old Mar 14, 2009 | 05:27 PM
ChopstiX's Avatar
ChopstiX
Originally Posted by DavesZ#3
See diagram...
wow thanks Dave.. now i know why you are a super moderator!!
Old Mar 15, 2009 | 12:13 PM
Kristi's Avatar
Kristi
I am Awesome
so i removed the water pump cover and also the 3 bolts holding it.. is it suppose to be able to slide out? it looks like there is a chain connected to the gear. anyones help would definately be appreciated.
Old Mar 15, 2009 | 12:57 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
kristi, do you have the service manual? Its not that easy of an uninstall.
Old Mar 15, 2009 | 02:32 PM
SuperBlack350z's Avatar
SuperBlack350z
negative.
i shouldn't. the timing chain should be around it. i'm pretty sure the chain has to be removed. I could be wrong though but isn't the whole timing cover suppose to come off?
Old Mar 15, 2009 | 09:08 PM
TheFarmer's Avatar
TheFarmer
No, the timing cover doesn't have to come off. You have to loosen and remove the chain tensioner (also shown in DaveZ's photo, item 1) to get enough slack off the chain to get the pump out.
I highly recommend a service manual or taking it to someone who knows what they're doing.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
350z82
Oct 1, 2015 06:25 PM
