Automatic Transmission Flush. PLEASE HELP!!
Old Mar 16, 2009 | 06:48 AM
ChopstiX's Avatar
ChopstiX
Default Automatic Transmission Flush. PLEASE HELP!!
Hey guys.. i have searched for a guide on an Automatic Transmission Fluid flush but I only see Manual Transmission Flush..
How many quarts do I need?
Is there a dipstick to check it?
Old Mar 16, 2009 | 08:13 AM
SuperBlack350z's Avatar
SuperBlack350z
i would take it to a dealership. there is a machine that sucks it out and puts new fluid back in. I don't think you can flush the whole auto tranny doing it at home.
Old Mar 16, 2009 | 08:28 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You can drain about 8-9 quarts out. About 2 quarts will be left in the TC. Tranny flush I think a flush is around $150 @ the dealership and is your best bet becasue the fluid is usually between $10-$12/quart. There is a dipstick behind your intake manifold on the left side. There is a 10mm bolt that holds it down.
Old Mar 16, 2009 | 11:13 AM
ChopstiX's Avatar
ChopstiX
oh i never seen that dipstick before... that sucks.. i dont want to have to bring the car to the stupid stealership!!
Old Mar 16, 2009 | 11:24 AM
ChopstiX's Avatar
ChopstiX
well heres the deal why i am even attempting to do this.. my girlfriends dad decided to disconnect some hoses running from the bottom of the radiator while we were working on the cooling system and apparently there were some hoses connected to the transmission fluid??? it looks like we lost fluid and i want to be able to top it off.. i just dont know whats the best way with approaching this..
Old Mar 16, 2009 | 12:27 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Yes, there is a cooler built into the radiator that those lines go to. If your miles aren't that high you prob don't need a flush. Check your dipstick and if the fluid is still bright red your good, just add what's needed. Check your level with the car on and do NOT put anything but the nissan j-matic fluid in there which you will have to go to the dealership for
Old Mar 16, 2009 | 12:30 PM
ChopstiX's Avatar
ChopstiX
I have the fluid already that i bought.. wheres the best spot to refill it at?
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
seagrasser
Oct 11, 2015 03:27 PM
