Disturbing Find
Old Mar 18, 2009 | 05:50 PM
mcarther101's Avatar
mcarther101
Unhappy Disturbing Find
So I just changed my spark plugs @ 65k miles. I was saddened to see that some oil is seeping into the combustion chamber. This was what they looked like...
New vs Old:
Old & Oily:
When I started up the car with the new spark plugs, there was white smoke from all the oil... it's all burned off now I think though. Doesn't seem to have affected performance though, last I dyno'd @ 244whp, 236wtq, and I haven't felt any loss of power since. I'm not sure how recent this seepage occurred though. Is this a pretty common issue?
Old Mar 18, 2009 | 06:11 PM
huyrua's Avatar
huyrua
What cylinder is it? Sounds like the same problem http://g35driver.com/forums/g35-seda...rranty-up.html
Old Mar 18, 2009 | 06:17 PM
Jay'Z's Avatar
Jay'Z
This is very common.. Dont worry.. Change your plugs in about 10k and check them again...
Old Mar 18, 2009 | 06:28 PM
tony530's Avatar
tony530
what is causing that??? the head valve gaskets going back??? i found that happening in my 3 cylinder...
Old Mar 18, 2009 | 06:44 PM
erban32's Avatar
erban32
valve cover gasket maybe.
Old Mar 18, 2009 | 06:47 PM
Flee0588's Avatar
Flee0588
definitely not your valve cover gasket.
maybe the head gasket.
Old Mar 18, 2009 | 06:51 PM
mcarther101
+1 I think that's what it is from what I've been reading. I plan on building a VQ35DE in the future so nbd... I'll deal with it then.
Old Mar 18, 2009 | 08:15 PM
That's a lot of oil in the combustion chamber.
Old Mar 18, 2009 | 10:28 PM
Asian Invasian's Avatar
Asian Invasian
hmm i should get mine changed and check this out.. it seems to be a problem.
Old Mar 19, 2009 | 11:02 AM
BallZdeepNYC's Avatar
BallZdeepNYC
i have a warranty for 10yr 100k miles. will nissan cover this? I need to know because i feel a lot of power loss from my car. compared to my buddies 335 i feel like im driving an 89 buick regal lol
Old Mar 19, 2009 | 01:12 PM
erban32's Avatar
erban32
If its not the valve cover gasket, then how did oil get onto the spark plug socket. and he said that it put out a puff of smoke after the new plugs were installed. after the oil that was in the spark plug tube ran down into the combustion chamber.
Old Mar 19, 2009 | 06:58 PM
BallZdeepNYC
Old Mar 19, 2009 | 07:15 PM
SchismX's Avatar
SchismX
Pretty common problem I have seen. There is a o-ring seal on the valve cover that sits around each plug, which seem to go bad quite often. I heard the only remedy for this is to buy a whole new valve cover because the o-rings can't be replaced individually.
What is your oil level like in between oil changes?
Old Mar 20, 2009 | 04:35 PM
mcarther101
Oil-level beween changes is fine. No noticeable oil consumption.
Old Mar 20, 2009 | 06:00 PM
Zorgazm's Avatar
Zorgazm
Im currently experiencing the same thing
https://my350z.com/forum/maintenance...e-worried.html
Uriyo_
Sep 8, 2021 08:46 AM
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
