Cupping--need Help Guys ! ! !
Old Sep 16, 2003 | 01:19 PM
Toby's Avatar
Toby
Default Cupping--need Help Guys ! ! !
Hey guys...Having severe cupping problems on inside of front wheels....what do know of this problem? Need help...is Nissan fixing this?
Old Sep 16, 2003 | 01:44 PM
Audito350Z's Avatar
Audito350Z
cupping sometimes indicates low tire pressure.... I'd check that before going up to the dealer. Not likely something that would be covered under warranty.
PeteH
Old Sep 17, 2003 | 07:54 AM
350zSpeedRacer's Avatar
350zSpeedRacer
See the several tire feathering threads in the repair section. You should be able to find answers in them.
Old Sep 17, 2003 | 12:19 PM
GixxerBB's Avatar
GixxerBB
yeah, bring it back to the dealer, they will fix the problem......my dealer replaced my front 2 tires!
Old Sep 18, 2003 | 04:04 PM
dr_gallup's Avatar
dr_gallup
Go to the dealer, they should be familiar with the problem. If not, tell them to look at the TSB Tire Road Noise NTB03-006. That instructs them to align the car and rotate the front tires which is not much of a solution. However, many dealers will go ahead and replace the tires right away. Mine did. The bigger problem is that it will most likely return even after the alignment. There are several lengthy posts here with more pissed off Z owners than you can shake a stick at.
Obadabot
Jun 18, 2023 11:31 PM
Alexreyes
Sep 30, 2015 11:30 PM
