First time oil changer!
Old Apr 12, 2009 | 01:09 PM
aDDandrew's Avatar
aDDandrew
Default First time oil changer!
So i decided to change my own oil from now on . Took me about an hour, plus cleaning the mess I made. One concern I have is, how tight does the oil filter have to be? Other than that, I think it went pretty well.
All the ingredients for an oil change
Draining her
nasty synthetic oil
Fresh out the bottle
Wtf do I do with the nasty oil?
Old Apr 12, 2009 | 01:14 PM
SchismX's Avatar
SchismX
Looks like you need to invest in a good oil drain pan.
Old Apr 12, 2009 | 01:15 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
and take it to an oil change place to recycle it.
Or do what I do and pour it out in the back yard.
Old Apr 12, 2009 | 01:21 PM
Chromex319's Avatar
Chromex319
This is a great investment.
http://www.automotivetools4less.com/...9496cfe7c94d2e
JK
Old Apr 12, 2009 | 01:54 PM
omegamanex's Avatar
omegamanex
Oil filter goes on 2/3 turn after it makes initial contact with the filter seal.
as for the used oil, any kragen or autozone type store should take it for recycling for free.
Old Apr 12, 2009 | 02:08 PM
SoldzMyZ's Avatar
SoldzMyZ
Yeah don't go crazy over tightening the oil filter. Doing so can mess up the rubber seal causing an oil leak (that happened to me on my eclipse. No permanent damange though but lost almost all my oil). Just a 2/3 turn after it is on their "finger tight".
Also buy an oil drain pan. You can buy it at autozone for less than $10. Buy it, place the used oil in the drain pan, and take it back to autozone (or kragen, or pepboys) to recycle for free.
Just a personal tip, I have an oil drain pan, but the oil (or any fluid for that matter ) is transported, I use an old big bottle of bleach. I find that its easier to transport than the massive oil pan I use and more secure to prevent spillage. I just turn the oil drain pan against the garage wall upside down and resting on the wall to drain into the bleach container.
Old Apr 12, 2009 | 02:27 PM
aDDandrew's Avatar
aDDandrew
I thought about the oil pan after I got her up on jacks lol, my laziness got the best of me so i used mom's cooking foil pans . Oil pan will be on the top of my to do list tomorrow.
Old Apr 12, 2009 | 03:51 PM
mclovin.too's Avatar
mclovin.too
Always nice to see someone working on their own car.
FYI next time, no need to jack up the back end too.
Old Apr 12, 2009 | 04:41 PM
I like the 100-piece tool kit. I think you need one wrench.
Old Apr 12, 2009 | 04:50 PM
Nexx's Avatar
Nexx
+1, its actually better to have the front end up higher so that the oil runs towards where the drain hole is located.
Old Apr 12, 2009 | 04:57 PM
jZ08's Avatar
jZ08
Default A couple of tips
I use this Dow Corning DC4 on the oil seal when I'm changing the oil filter on my airplane. I have a calibrated snap-on torque wrench and can confirm that the hand tighten, then 2/3rds turn will put you right in the ball park for the specified torque for a filter.
What DC4 looks like
If you're really picky about knowing how your engine is doing use these guys to do an oil analysis. Blackstone-Labs They compare your engine against its brethren at the same point in the engine's life. I.e., your VQ35DE oil analysis will be compared against other VQ35DE engines.
From the photos that oil looks like it was ready to come out a while ago, but I'm kinda finicky.
I've got 400 miles to go on my engine break-in. I can't wait to pop her cherry.
Old Apr 13, 2009 | 07:33 PM
jenner1's Avatar
jenner1
changing your oil is a pretty silmple process but for the time and the pain in the *** of getting rid of your used oil all the time I just run it through a drive through lube service. Most reputable shops will carry good oils like amsoil and royal purple; plus if anything happens regarding loss of oil and engine damage its the shops problem not yours. Most shops will keep a computer record linked to your vin number as well so there will always be a record of changing your oil if you have to have any warranty work done on your engine.
Old Apr 16, 2009 | 04:40 PM
wasyed's Avatar
wasyed
Hey aDDandrew I was wondering where you purchased the Royal Purple and if you dont mind me asking for how much? The only reason I ask is because I found it at a local walmart for $6+ and was wondering if thats a good price per qt. I'll be doing my first oil change on my 350z soon but was looking around for decent oil first of course. I've always used mobil 1 syn. on my maxima and altima but wanted to try out the royal purple in the Z.
I think it was $6.68/qt or $6.95, Decent price?
Thanks in advance
Old Apr 16, 2009 | 04:47 PM
mclovin.too
Old Apr 17, 2009 | 04:26 PM
j.arnaldo's Avatar
j.arnaldo
...I used to do my own oil changes, but carpal tunnel syndrome's got the best of me, so now I actually have to pay for it (I take my own 5W30 MOBIL 1 and filter, OF COURSE!). I'm getting therapy to improve the condition, though...sob...
Old Apr 24, 2009 | 04:20 PM
Xzero's Avatar
Xzero
I am also a first time oil changer(on my Z!) I've many jobs working on engines & have done thousands of oil changes back in the day but I've been lazy and kept getting free oil changes & getting most of my fluids changed from the dealership so that I would have records.
But know I'm like "Screw that!" My fluids are always clean so I may as well do everything but the tranny(5AT) myself & write down mileage when I do it!
I'll save on all the dealer fees & I get to pick what goes in my car now!
Amsoil & ATE all the way!
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
