Oil life reset
Old Apr 15, 2009 | 02:08 PM
pistol820's Avatar
pistol820
Default Oil life reset
I just changed my oil but I don't know how to reset the oil life percentage. Can someone give me a way on how to do it..Thanks. Its a 2004
Old Apr 15, 2009 | 04:39 PM
KornerCarver's Avatar
KornerCarver
I didn't know you could do that.
Old Apr 15, 2009 | 04:43 PM
pistol820's Avatar
pistol820
It's in my 04 GMC Yukon it tells you when to change the oil percentage wise.
Old Apr 16, 2009 | 05:45 AM
blastoff99's Avatar
blastoff99
I am very confused.
Do you want us to tell you how to reset the oil life percentage thingy in your Yukon, or are you trying to operate a non-existent feature in your 350Z?
Old Apr 16, 2009 | 07:07 AM
pistol820's Avatar
pistol820
Originally Posted by blastoff99
I am very confused.
I was told that a light will come on indicating the oil needs to be changed. Is that true ?.
Old Apr 16, 2009 | 07:13 AM
crg914's Avatar
crg914
No. Not on a Z.
Old Apr 16, 2009 | 07:15 AM
06blueZ's Avatar
06blueZ
Old Apr 16, 2009 | 07:21 AM
pistol820's Avatar
pistol820
You got it 06blueZ, I am refering to a 04 350Z, besides changing the oil is there any sensors that have to be reset ?
Old Apr 16, 2009 | 07:23 AM
06blueZ's Avatar
06blueZ
ah, ok, sorry i don't have navigation so i'm not much help... maybe in the owners manual?
Old Apr 16, 2009 | 07:26 AM
Xlr82x's Avatar
Xlr82x
only light that should come on if you don't change your oil is the Engine light and that case just kiss the car good bye... Haven't seen a stock oil sensor unit like the one you speak of.
Old Apr 16, 2009 | 07:32 AM
pistol820's Avatar
pistol820
Thanks for the info.
huyrua's Avatar
huyrua
Z's don't have oil change indicator.
Old May 7, 2009 | 07:26 PM
Jeff_04z's Avatar
Jeff_04z
Default how to reset oil light on a GMC
put the key in the ignition at the "key on"(don't start) position and press the gas pedal 5 or 3 times.
Then turn truck off for awhile then "start"
Old May 7, 2009 | 09:31 PM
Vader007's Avatar
Vader007
Its part of the factory nav system, the reset is in the menu.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
