Is this D2R HID bulb burned out?
Old Apr 22, 2009 | 07:30 PM
Midas78's Avatar
Midas78
Default Is this D2R HID bulb burned out?
Can someone tell me from looking at the pictures if the bulb is burned out? Of course, it doesn't light up anymore, but I rather just replace the bulb than a ballast. I've also noticed condensation under the headlight lense, so maybe moisture pre-maturely wore it out (IDK). Thanks for your help.
Old Apr 23, 2009 | 04:58 AM
Midas78's Avatar
Midas78
Anyone here with HID experience that can help?
Old Apr 23, 2009 | 10:25 AM
zettahertz's Avatar
zettahertz
just plug it into the working side and see if it lights up? Or just swap the bulbs, and you'll get your answer. Kinda hard to tell by just looking at it.
Old Apr 23, 2009 | 11:27 AM
Midas78's Avatar
Midas78
I thought about that, but I didn't find out and get to working on it until after church last night. I'll try swapping the bulbs after work today.
I called the Nissan dealership for one D2R bulb, they want $191.
Old Apr 23, 2009 | 12:22 PM
Squeaky350's Avatar
Squeaky350
You can find cheaper bulbs online.
On a side not, what camera is that? That is a clear picture.
Old Apr 24, 2009 | 06:30 PM
Midas78's Avatar
Midas78
I swapped the bulbs and the bulb is good. I opened up the headlight and there was water in the ballast. I'm drying it completely out and resealing it, hopefully it'll work again, otherwise I'll be in the market for a new ballast.
The pics were taken with a Nikon D60.
Old Apr 24, 2009 | 06:40 PM
diwun67's Avatar
diwun67
It's hard to tell because HID bulbs don't have a filament that burns out like a normal bulb. Likely it's usually the ballasts that go bad from moisture, like in your case. Same thing happened to me, I let it dry out and it worked fine.
Old Apr 24, 2009 | 06:42 PM
Italianjoe1's Avatar
Italianjoe1
The whitish color in the bulb looks like it is starting to get worn out, but since you already found the problem, I guess that has nothing to do with it. I had a bulb burn out on me once, had a brownish color where yours has that milky look to it. Usually when just a bulb is bad, it will still try to power on, just won't kick on to full power. The ballast will still try to light it off but can't. Bad ballast won't do anything at all usually, but it depends on what exactly goes 'bad'.
Old Apr 24, 2009 | 10:02 PM
Midas78's Avatar
Midas78
I just dried everything out, touched up the paint on the housings, sealed the lens like a ****, and still no light. I'm looking for a ballast now.
Thanks for your help, hopefully someone else can use this thread when their xenon light goes out.
Old Apr 27, 2009 | 06:12 AM
Midas78's Avatar
Midas78
Talking
Update - after driving from Melbourne to Tampa (~140 miles), when I turned on the headlights to leave the HIN show - the driver's side headlight came on.
I guess there was a little more drying out to be done and now both headlights work.
Old Sep 17, 2011 | 08:06 AM
ROCA Z's Avatar
ROCA Z
it just happened to me.......
moisture got in, and condensed all the water at ballast.. I'm in the drying process.... wish me luck ill post the result later
Old Sep 17, 2011 | 09:42 PM
ROCA Z's Avatar
ROCA Z
It's all working now !! The drying worked ... Seal that like boss lol good luck to the next unfortunate !!!
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
apex locator
Jul 23, 2021 02:27 AM
allmycarsdie
May 13, 2016 04:38 PM
hardwood66
Sep 8, 2015 04:31 AM
