Wa Wa Wa sound
Old May 7, 2009 | 08:49 PM
Psychobilly's Avatar
Psychobilly
Default Wa Wa Wa sound
I have a 2008 base model 350Z with 8000 miles. As I drive I hear a "wa wa wa" sound. As I speed up the sound goes faster. Could it be my tires?
Has anyone experienced the same issue? What should I expect from the dealer when I bring this issue up?
Old May 7, 2009 | 09:26 PM
Gibbs's Avatar
Gibbs
Know it all
2008 = Waranty. Go to the dealership!
Old May 7, 2009 | 09:34 PM
Bolaz's Avatar
Bolaz
God damn it, i have to make this work..... 2nd try!
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/jRpIhYwg7Tw&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/jRpIhYwg7Tw&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
If not here is the damn link:
http://www.youtube.com/watch?v=jRpIhYwg7Tw
Old May 7, 2009 | 09:35 PM
jduet's Avatar
jduet
Originally Posted by Bolaz
this is the problem...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/n79jSzKA0L8&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/n79jSzKA0L8&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
That is a problem IMO
Old May 7, 2009 | 09:48 PM
Bolaz's Avatar
Bolaz
I FAIL
I tried re doing it, but its not working for some reason
Old May 8, 2009 | 12:31 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Sounds like a baby. You should turn it in to the closest fire station.
You need to be more specific for us to help you. You're better off just going to the dealer with your warranty in place.
Old May 8, 2009 | 01:05 AM
_STEVEO_01's Avatar
_STEVEO_01
: I was gonna make a similiar comment Rick, but ya beat me to it...
Old May 8, 2009 | 01:38 AM
0jiggy0's Avatar
0jiggy0
sounds like your describing a bearing noise. go to the dealer
Old May 8, 2009 | 05:37 AM
Probably the wa-wa valve is jammed-up with backpressure.
Old May 8, 2009 | 07:22 AM
Paintballislife's Avatar
Paintballislife
someone say wawa?
Old May 8, 2009 | 08:59 AM
Psychobilly
Here's a better description:
10 mph: wa...................wa......................wa............. ... etc.
20 mph: wa.......wa........wa.........wa..........wa.......wa....... . etc.
30 mph: wa....wa....wa....wa....wa....wa....wa... etc.
40 mph: wa..wa..wa..wa..etc.
I'm taking it to the dealer on Monday.
So with the exception of the guys who have babies in the "backseat" of their 350Z, hopefully they're using a child seat, does anyone have any experience with this problem?
Old May 8, 2009 | 10:32 AM
cheshirecat79's Avatar
cheshirecat79
It's your tires. Is it almost like a whum whum sound?
I think it's more of a woo-woo sound, myself.
WOO WOOOOO.
Old May 8, 2009 | 10:45 AM
06blueZ's Avatar
06blueZ
may be a damaged differential. does the wa wa change at all between acceleration and deceleration? with the open rear on the base its prone to bad wheel hop which can damage the rear diff..
Old May 8, 2009 | 12:22 PM
Psychobilly
The sounds stays consistent. It does sound like it's coming from a rear tire.
Old May 9, 2009 | 03:16 PM
Z&G's Parts Dis's Avatar
Z&G's Parts Dis
Vendor - Former Vendor
most likely its a tire. Try to narrow down the location of the sound. Front? Back? Left? Right? If you had recently slammed on your brakes really hard, that could have caused a slight bald spot on your tire. This had happened to me on my chevy truck. For the longest time i thought the freeway was really getting out of shape, but winds up it was my tires
Old May 12, 2009 | 06:19 AM
Psychobilly
Default Diagnosed
It was a wheel bearing and covered under warranty.
Old May 12, 2009 | 06:21 AM
Goku350z2007's Avatar
Goku350z2007
mine makes a choo choo sounds : )
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
