Rear suspension, hub, wheel? Squeaking & Creeking over speed bumps/driveway
Old Jun 7, 2009 | 07:39 PM
rodH's Avatar
rodH
Default Rear suspension, hub, wheel? Squeaking & Creeking over speed bumps/driveway
OK, I am finally so sick of those it is driving me crazy. It has been going on for a few years now, and I need to fix it ASAP.
I did a search but a lot of people talk about the interior of the car making the noise (rear strut, rear panels, window, seals, brake light, etc....). Mine is DEFINITELY coming from the EXTERIOR.
Here is the thing, it creeks and squeaks when:
1. Driving slowly over speed bumps
2. Driving up or backing down driveway
3. Cornering and I am next to a wall to reflect sound and not on the throttle
4. Worse when car is cold and cold out side
5. Slightly less when brakes or E-Brakes is applied
6. Can be reproduced just having it sit in my garage and rocking the car back and forth (it has gotten that bad).
7. Right side is worse than the left, but both are effected
It literally sounds like old creaky wood floors from an old house.
Car: 2003 Touring
Suspension: Back to stock, but I did have some Hotchkis springs on before and it did it with those as well.
I have tried a couple easy fixes, but nothing has really cured the problem. I have tried to tighten some of the easily accessable bolts on the suspension parts and brakes. and I have tried spraying a ton of lube to the whole rear trying to see if it would work.
ANY HELP WOULD BE GREATLY APPRECIATED!!!
Old Jun 7, 2009 | 08:44 PM
freedonutss's Avatar
freedonutss
How many miles are on the stock shocks? My shocks are worn out and they make squeaking noises on bumps. You were also lowered at one point which causes the shocks to wear out faster.
Old Jun 9, 2009 | 08:45 AM
rodH's Avatar
rodH
Started making noise at about 20k miles, it now has 45k, it isn't the shocks. It was only slightly lowered.
Old Jun 13, 2009 | 05:46 AM
ChinaClipper's Avatar
ChinaClipper
I had a similar problem, (though it did not seem to sound as loud as your problem), and it turned out to be the exhaust system hangar at the right rear of the car coming out of the rubber strap. Check all of your exhaust system hangars. HTH
Old Jun 15, 2009 | 02:58 PM
maXmood's Avatar
maXmood
Under Boost!
ok, maybe u had it as ur last resort, but i'd suggest it.. take it to the stealership to get it checked/fixed..
Old Jun 16, 2009 | 12:41 PM
rodH's Avatar
rodH
JUst checked, not the exhaust
Old Oct 7, 2013 | 12:32 PM
Diggles's Avatar
Diggles
never figured it out , having same problem ...?
Old Oct 7, 2013 | 01:22 PM
ChinaClipper
A follow-up. A number of fellow Z Club members have had this similar problem, and it is attributable to loose/worn hardware in the sway bar end links. Disconnect and remove your end links completely from the car, and shake the sway bar to make sure it is not loose in the sway bar bushings. In fact, it should be so snug that without the end links attached, the bar will barely move/swing by hand on the car. Temporarily secure sway bar ends with baling wire for test drive without end links. If it is an end link problem, the noisiness/squeaks/rattles should be gone when test driven on the street. Replacing with brand new end links then is advised. If you have aftermarket sway bars, then aftermarket end links such as Whiteline, etc. is advised.
Old Oct 9, 2013 | 12:26 PM
Convexum37's Avatar
Convexum37
^ the answer
same thing happened to me last year. Tried everything, replaced rear end-links and the problem disappeared.
Old Oct 15, 2013 | 07:20 AM
Diggles's Avatar
Diggles
thanks for the response , I will try that
Old Oct 22, 2013 | 07:42 PM
350zChick13's Avatar
350zChick13
Default bushings
This kind of sounds like the problem I am having with the front of my car. Everyone has told me control arm bushings. Yours could possibly be the sub frame bushings or the control arm bushings. I would say if you are still having the problem check them out and give it a shot.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
