A/C receiver/ drier
Old Jun 23, 2009 | 08:49 AM
phre4ker's Avatar
phre4ker
Default A/C receiver/ drier
I need to replace the A/C drier in my 03 350Z. One of the lines had a bad leak (nothing left in the system) and I am replacing the line as well. I did a search and do not see anyone else posting information on the drier. I expect(ed) it to be a quick part swap, but the packaging indicates it is under pressure, etc. Are there any precautions I need to take before installing the new drier, or am I just asking a stupid question over a $20 part? Thanks for your help in advance, guys.
Old Jul 5, 2009 | 06:56 AM
Titan0385's Avatar
Titan0385
The a/c drier would need to be drained first if it was under pressure.. but since you developed a leak you will be fine to do it yourself.. I just replaced the drier in my 350z.. It was a simple fix.. Under screw the bracket holding the lower hard lines on, loosen the bracket holding the middle bracket and spread it wide enough to push the recver dryer up and out.. once the recver drier is out disconnect the plug on the top.. once this is completed, you can install the new drier in reverse order.
PM me if you have any questions...
Old Jul 6, 2009 | 09:04 AM
VO...'s Avatar
VO...
Administrator
Will the system need to be recharged after the installation? (Freon/coolant)
Old Jul 6, 2009 | 10:17 AM
Titan0385's Avatar
Titan0385
From what I did, yes.. because my drier and the line running from the compresser to the hard lines by the radiator needed replacing, I needed to refill the system.
FYI.. Our a/c system requires 1.21 lbs of coolant..
Old Jul 10, 2009 | 06:11 AM
phre4ker's Avatar
phre4ker
Default more issues
Purchased the part, removed old drier, the drier the auto parts store gave me has no place for the pressure sensor. It's going to be 101+ degrees here this weekend, and I wanted it taken care of. Dealer can have one by Tuesday, which is fine, but little too late. Anyone else experience this problem? I attempted an order from Orielly and Advance Auto parts, which failed, and even Auto Zone can't tell me if theirs has the threading for the pressure sensor. I'm surprised, did Nissan use more than one drier on different Z's, or did the people around here ride the short bus? If someone could send me the part number for a receiver drier from an auto parts store, I'd appreciate it. It's HOT!
Old Jul 13, 2009 | 08:32 AM
Titan0385's Avatar
Titan0385
I ordered my receiver drier from Import Auto Wholesale online. They have really fast shipping, the part is dirt cheap, and is a direct bolt in.
Here's the link to the part:
http://www.importpartswholesale.com/...iverdrier.html
Old Jul 30, 2020 | 12:43 PM
Elito Irizarry's Avatar
Elito Irizarry
5 Year Member
do u have to pull off the bumper or can you reach it from over or under
bjgordon
May 28, 2004 09:10 PM
Daytona Blue Z in Bo
Jan 27, 2004 04:58 AM
manrey
Jan 7, 2004 02:10 PM
emu29
Jul 16, 2003 07:51 PM
