Door losing power
Old Jul 30, 2009 | 12:59 PM
smartparts15's Avatar
smartparts15
Question Door losing power
Hey guys, I've been having this problem for awhile now. When the door is closed it completely loses power(no windows, locks, or mirrors) originally I thought it was the window motors going bad, but then I noticed they would work when the door was ajar. So basically, to get power to the doors I have to open my door, to roll up my windows, or adjust my mirrors. I've taken the panel off and looked at it, but I can't see any damage that would cause this issue.
Has anyone else had an issues similar to this?
The car is a 03 Performance, with about 52000 miles on it.
Thanks in advance,
Alex
Old Jul 30, 2009 | 03:10 PM
vthao's Avatar
vthao
Check the wires that go to the switches on the door. Seems like when the door is closed, you're losing a ground or something, like a wire not touching properly. Good luck!
Old Jul 30, 2009 | 03:23 PM
eski8612's Avatar
eski8612
Default quick question about the a window problem
i noticed that when im in for the night and or park somewhere for a while
usually happens if it rains alot the night before but when i go back to my car the windows magically rolls down by them selves and yes i do roll up the windows when i leave my car and lock the doors so if anyone knows how to fix this problem id be grateful thanks
Old Jul 30, 2009 | 04:00 PM
hndumafia's Avatar
hndumafia
I was having a problem with my passenger door losing power (except that the window down function would still work). I pulled apart the harness where it connects from the car to the door assuming I had possibly damaged one of the pins in the harness when I ran speaker wires to the doors (6+ years ago), but everything looked fine. So, I just used an air canister to clean the dust and sprayed a little contact cleaner, and put everything back together. And ever since, it's been working perfectly again. It's possible the electrical contacts were just dirty, causing the problem. May work for you also.
Old Jul 30, 2009 | 04:27 PM
eski8612's Avatar
eski8612
thanks bud imma hop on that as soon as this crappy weather clears up
thanks again
loudtoyz
Apr 6, 2023 04:52 AM
codek
Sep 28, 2015 03:03 AM
