"abs" "VDC OFF" "SLIP" lights up, please help
Old Aug 8, 2009 | 04:42 PM
heinzlester's Avatar
heinzlester
Default "abs" "VDC OFF" "SLIP" lights up, please help
hello
i recently purchased a greddy touch infometer to be connected to the OBD.
on several occasions while driving, i noticed the "ABS" "VDC OFF" "SLIP" indicator lights up all at the same time, but it goes off when i turned off the engine. it seems ok after a while, but after sometime the three lights u again...
this never happened before do you think the infometer has something to do with causing the 3 indicators to go on or maybe there is some other causes.
your advise will be greatly appreciated
thanks!
Old Aug 8, 2009 | 04:48 PM
erichsherrill's Avatar
erichsherrill
this might help a little it isnt exaclty what you are describing but it may be informative..u didnt mention your brake light coming on so i dont know..
https://my350z.com/forum/brakes-and-...need-help.html
i had a similar problem and it ended up being my brake pads being very low..
Old Aug 9, 2009 | 05:00 PM
Accordaleer's Avatar
Accordaleer
I picked up my car from the bodyshop in feb, was so excited to have it back and took off down the highway.... took it to redline and Slip light, TCS, and SES lights all came on instantly.... took it to the dealer and it turned out to be my crank position sensor that went bad. It was covered under warranty and apparently was the easy sensor to replace because theres another one on the motor that takes a long time to replace. I don't have VDC myself being in auto. Connecting your new toy mighta just been a coincidence.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
