Need help!!! VDC and SLIP light on!!!
Old Aug 19, 2009 | 11:51 AM
Nismokingz33's Avatar
Nismokingz33
Talking Need help!!! VDC and SLIP light on!!!
So I was searching the forum but I could not find anything that could help. My vdc and slip light come on as soon as I start driving like the first few feet I move they both com on. I have had a similar problem but it was my BREAK light VDC and SLIP but I fixed that it turned out to be I didn't have enough break fluid.
But now it's my VDC and SLIP light only?
I change my rear break pads today but they still come on????
Any help will be greatly appreciated
Old Aug 19, 2009 | 12:20 PM
Have you added new tires recently? What size?
Old Aug 19, 2009 | 01:00 PM
Nismokingz33
I have 19 inch rims but I have had them on for about 2yrs now.
Old Aug 19, 2009 | 02:22 PM
DavesZ#3's Avatar
DavesZ#3
According to your owners manual:
VEHICLE DYNAMIC CONTROL
(VDC) SYSTEM (if so equipped)
 Indicator light
If a malfunction occurs in the system, the
“SLIP” and “VDC OFF” indicator lights illuminate
in the instrument panel
. As long as these
indicators are illuminated, the VDC system
function is canceled.
 If engine related parts such as a muffler
are not standard equipment or
are extremely deteriorated, the “VDC
OFF” indicator or “SLIP” indicator or
both indicator lights may illuminate
 Do not modify the vehicle’s suspension.
If suspension parts such as
shock absorbers, struts, springs, stabilizer
bars and bushings are not
NISSAN-approved or are extremely
deteriorated the VDC system may not
operate properly. This could adversely
affect vehicle handling performance,
and the “VDC OFF” indicator
or “SLIP” indicator or both indicator
 If brake related parts such as brake
pads, rotors and calipers are not
standard equipment or are extremely
deteriorated, the “VDC OFF” indicator
 If wheels or tires other than those
recommended are used, the VDC sys-
tem may not operate properly and the
“VDC OFF” indicator or “SLIP” indicator
or both indicator lights may
illuminate.
My first guess would be your front brake pads need to be replaced. Second, you have a malfunction in the system - it needs to be checked.
Old Aug 19, 2009 | 03:10 PM
Nismokingz33
 Indicator light
. As long as these
illuminate.
Well I just got a BBK in the front about 3 months ago if there was a malfunction in the front breaks it would have started doing the SLIP light and VDC as soon as I would have driven it from the shop right??? Second my rear tires are worn down not sure if that could be it because I use to have 20's with worn tires and never had this happen to me? By the way I have 19's now.
Old Aug 19, 2009 | 03:53 PM
DavesZ#3's Avatar
DavesZ#3
It could be low pads or it could be a bad wheel speed sensor. Because the lights trigger immediately, I'd suspect a malfunction in the system before worn tires, etc.
Old Aug 19, 2009 | 07:22 PM
Nismokingz33
Do you think any mechanic would be able to pin point the problem or should I take it to the dealership?
Old Aug 20, 2009 | 05:00 AM
DavesZ#3's Avatar
DavesZ#3
A mechinic can check the obvious like word pads. But he'd need the diagnostic capabilities of the Consult system to test the ABS/TCS/VDC computer, speed sensors, etc. That's something only dealers have access to unless you find a big shop that specializes in Nissans.
Old Aug 23, 2009 | 04:25 AM
gyotar's Avatar
gyotar
I just had the same thing happen to me last night. I just started my car and it imediately died/check engine light/VDC Off/Slip Light came on. Restarted the car, and after reving it a little it held idle no problem. Drove home no problems except my dashboard looking like a christmas tree. Reset the ECU and the VDC/Slip lights disappeared but the Check engine light is still on.
Old Aug 23, 2009 | 01:18 PM
DavesZ#3's Avatar
DavesZ#3
CEL means that you need to get the code read to find out what's wrong. If you dash lights up like a xmas tree - then you have a real problem.
Old Aug 23, 2009 | 01:24 PM
gyotar's Avatar
gyotar
I was exagerating a bit. On the drive home the SES, VDC Off, and SLIP lights were on. Like I said, pulled ECU fuse and all but the SES light disappeared.
The car has stalled once or twice right after startup in the last year but nothing ever came of it. I wonder if they are related in some way. I would say my tire sizes might play a part however I wasn't moving and I've had this size tire on for a couple years.
Drove around all morning with no problems so I'll get the dealer to pull the code and see what comes up.
Old Aug 24, 2009 | 08:56 PM
Accordaleer's Avatar
Accordaleer
My crank position sensor went when I had those lights come on while driving...
Old Aug 25, 2009 | 02:23 AM
gyotar's Avatar
gyotar
I reset the ECU and manually cleared the SES light and there hasn't been any problems since Saturday night. If it comes on again I'll do something about it.
Old Sep 5, 2009 | 07:22 AM
juan350z25's Avatar
juan350z25
Default slip light ON and OFF
hey guys, im having the same problem too. i put a new HKS hi- full ehaust yesterday and 19inch wheels on my 04 z, and couple hours later, the slip sign came on... when this happpens the car slips it feels sliping actually, i dont know if its the clutch or what but if i shift back it goes away and acceleration is normal, what do you think it is?
clutch, etc. clutch feels fine to me.. maybe my ehaust or wheels?
please reply
thanks
Old Sep 7, 2009 | 04:15 AM
gyotar's Avatar
gyotar
Yes I also feel the slipping. The SES came back two weeks later so I'm going to take it in.
Old Sep 12, 2009 | 09:10 PM
gyotar's Avatar
gyotar
Cam Shaft Position Sensor replaced and no more problems...try it.
Old Sep 15, 2009 | 04:09 AM
sleeper832's Avatar
sleeper832
looks like i came to the right thread. my car has stalled twice this morning, and lurched a little last night. i checked the codes and im throwing a p0340 (camshaft position sensor - bank a).
so, now I need to replace this. Is this sensor approachable, or should I take it to a mechanic? Also, if it isn't too difficult, can anyone tell me where it is? Thanks.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
